These should do the trick:
â–º Original VW LED 1K8943021 Volkswagen 1K8943021C Golf Scirocco Amarok Passat | eBay
And you'll need these adapters to handle the current drop and prevent the bulb-out code:
Volkswagen â–º Plug Play Canbus Adapter â–º VW LED Kennzeichenbeleuchtung â–º Can Bus | eBay
These are fine for the Golf and Passat 3C, but best to take a look at your CC and confirm they're the same physical size and shape. My father has a CC so I'd check for you, but he's in NSW and I won't be visiting for a while. You could also message carsystems.pl (eBay seller) to confirm fitment and compatibility.
