Results 1 to 10 of 17
Thread: Noisy engine on startup - timing chains?
    Nov 2013
    Hi,
    I'm looking to buy a 2009 CC from a chap in Adelaide. I am in NSW so I had it checked by Miro from MRL Automotive (great guy, very helpful). Anyway, he noticed that the engine was noisy on startup and was worried it was the timing chain or maybe just in need of an oil change. After a re-start the noise was gone.
    Has anyone heard about timing chain problems with these cars? Can VW diagnose the problem without dropping the engine? Should I avoid this car?
    Any help would be apreciated
    Mine's start up sound is noisy too. Don't think it's a problem. It settles down after about half a minute if not driven.
    Great car. It's the gear box you should pay extra attention to.
    Good luck
    Just saw this post by Adam in the other thread.
    "The DQ250 6-speed wet-clutch DSG in the CC is a much more reliable unit overall than the more problematic 7-speed dry-clutch DQ200 DSG that has been the subject of recent recalls."
    Erskineville, NSW
    It's probably just an oil change. My chain driven EA888 gets an initial chain noise that disapears almost immediately but after an oil change it's quiet for a fair while.
    Miro is worth listening to
    Jan 2013
    Brisbane, QLD.
    If it only does it on cold start ups then fine the next time you turn it on (when its warm etc) then it wont be the chain, the VR6 fitted to the Passat can have timing chain noise problems (seen 1 or 2) but they are only replaced when you can Constantly hear the rattle, on cold start its fine as the oil can sometimes take a little while to get to the head. A oil change wouldn't hurt as others have also said.
    Mar 2014
    Sutherland Shire Sydney NSW
    Quote Originally Posted by The One View Post
    Our V6 CC has almost always rattled when cold, new oil or not. Of course VW service couldn't hear it. Also I understand quite a few others have 'it' too, so I understood it to be fairly common...?? What it is??????
    V6 CC - Love it - ------------------ - Golf V 2.0 FSI
    S3 Sportback - S-Tronic, Daytona Grey, Assistance package, magnetic Ride, B&O Sound system, Hold Assist, Load through facility with rear arm rest, 5 twin spoke star wheels.
    RS5 Sportback - Daytona Grey - New addition 2019
    Dec 2008
    Sydney/Canberra
    Most do it when cold, for about 10 seconds at most. Newer ones had a better chain tensioner on them, that didn't slacken the chain off when the oil bled down.
    Worst one I've heard, took a good few minutes to quieten down.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Mar 2015
    NSW
    Here's the thing, if it is only noisey for ~10 seconds as others have said, no problem, it's normal as the oil gets to the hydraulic lifters, camshaft adjuster and timing chain tensioner. If it does not settle down, you have problems.
    The best way to test if you have a timing chain guide wear issue is to restart a hot or even warm engine after letting it sit for a few mins. If it's noisey, you have this problem
    It's an expensive repair requiring lots of labour. Allow ~$2000 to do it privately, ~$3500 via a dealer
    This is only relevant to the V6 3.6L Passat / CC / R36 2005-10 as far as I'm aware. Though I have seen similar issues on earlier VR6 engines
    Dec 2014
    I own a 3.2L VR6 and my engine only got to 64,000km before the timing chains needed replacing (as well as the sprockets and tensioner). It was an expensive job! My understanding is that prior to the 3.2L VR6 that came out in 2005, previous engines had timing belts. Chains were supposed to avoid having to change the belt, but it did not work out that way because early examples of the 3.2L engine and possibly the 3.6L engine as well had chains that were not up to the job. They failed early, but VW did not do a campaign or recall on them.
    At some time around the middle or towards the end of the B6 run of 2005 - 2010, VW redesigned the timing chains and gave them a new part number. The engines with the revised chains are supposedly better. That also goes for other parts of the engine that are prone to failure such as the camshaft adjusters.
    2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
    Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
    Dec 2008
    Sydney/Canberra
    All VR6 motors are chain driven. The V6s found in the Passat previously, were belt-driven.
    Not sure if the chains were superceeded, but the tensioners definitely were.
    '01 Beetle 2.0
