Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Long Term Comparison: Passat R36 vs Passat CC V6 4Motion
    Quote Originally Posted by Passat R36 View Post
    They are basically the same car, only the tune is different.
    They can have exactly same equipments if you option up.
    R36 has active cornering lights too!
    Jees must be something wrong with mine then, lol
    MY19 Tiguan Wolfsburg w/roof (on the way)
    MY09 R36 Wagon
    MY12 CC V6 (sold)
    MY12 Scirocco (sold)
    Quote Originally Posted by Umai Naa!! View Post
    Springs should fit, but they'll be a bit too soft due to the weight difference bewteen the two cars.
    Thanks Dean
    MY09 R36 Wagon
    MY12 CC V6 (sold)
    Great comparison and write up Elmura.
    Correct me if I'm wrong. I wouldn't think the DCC is that sophisticated? I thought it is just a valve switch like what's on my motorbike.When you put in sport the valve closes more - compression & rebound becomes harder, and vice versa? So no sophisticated sensors or computers to work constantly I would think?
    Quote Originally Posted by dero View Post
    Was your CC standard fitted with the Dynamic Chassis Control and you lowered the springs on the car after the fact?
    I've been trying to figure out if its possible to do so without a lot of additional recalibration work. My Passat I had optioned with DCC at purchase and have been considering if its possible to lower the springs to the car for a better look. What I haven't been able to find out is if it'd break the shock absorbers in doing so. As I understand, DCC has shock absorbers with an electrically controlled constriction valve. Sensors monitor the relative wheel position against the body to recognise whether there is body roll occurring against the corner. If excessive, it'll clamp the valve in the shockie and force a flattening out of the corner experiencing the body roll.
    The thing that I've been puzzled with is if I lower the springs, would the sensors all of a sudden be measuring that all 4 corners are experiencing a level of body roll and therefore constrict the shock absorber's valves and keep them constricted throughout. Thus it could possible ruin the shock absorber and heavily affect the ride. I can't get anything definitive about this so have been hesitant in planning the lowering of my car.
    Mar 2015
    NSW
    By memory, I believe DCC to be adaptive to road conditions with the pre sets setting the base reference. It also firms the steering. I don't believe it affects roll (sway) adaptively
    Sent from my LG-D802 using Tapatalk
    Dec 2008
    Sydney/Canberra
    There is a travel sensor at each corner of the car. Similar to what's required for Xenon headlights.
    The steering weight is altered by slowing down the motor in the rack, reducing the amount of assistance given.
    If you can find the SSP online called Adaptive Chassis Control, it explains how it all works.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
