Great comparison and write up Elmura.
Correct me if I'm wrong. I wouldn't think the DCC is that sophisticated? I thought it is just a valve switch like what's on my motorbike.When you put in sport the valve closes more - compression & rebound becomes harder, and vice versa? So no sophisticated sensors or computers to work constantly I would think?
By memory, I believe DCC to be adaptive to road conditions with the pre sets setting the base reference. It also firms the steering. I don't believe it affects roll (sway) adaptively
Sent from my LG-D802 using Tapatalk
There is a travel sensor at each corner of the car. Similar to what's required for Xenon headlights.
The steering weight is altered by slowing down the motor in the rack, reducing the amount of assistance given.
If you can find the SSP online called Adaptive Chassis Control, it explains how it all works.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
