Results 1 to 10 of 11
Thread: Noisy AC
    Jul 2014
    Noisy AC
    So this car is starting to wear very thin on me..
    Got in the car this afternoon, started it, air conditioning powers up and makes a noise as if something is striking the fan. Noise increases and decreases based on the speed setting. AC on/off doesn't have an affect.
    https://youtu.be/fUGPH80plMY
    Dec 2008
    Sydney/Canberra
    Sounds like leaf litter in the blower fan.
    When was the cabin filter last replaced?
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jul 2014
    Major service last Thursday. I'll check the job sheet but I'm sure that is something that would've been done.
    I suppose that makes sense though. All this rain, moisture in the air, probably why the air smells damp when the AC is off.
    The car is going back tomorrow for castor bush replacement, they can check it out.
    Jul 2014
    Stuffed blower motor.. $650 supply and install..
    Think I'll do the work myself thanks.
    Dec 2008
    Sydney/Canberra
    They're not too hard to do. Probably 30 minutes tops.
    Glovebox out, and the blower motor is basically the bottom section of the HVAC unit.
    '01 Beetle 2.0
    Jul 2014
    I think it's also possible to do without removing the glovebox. We shall find out tomorrow
    Jul 2014
    Noisy AC
    EDIT - scratch that.. Found the little locking tab
    Jul 2014
    Thanks Becke......
    Took the opportunity to have a look at it myself this afternoon. **** of a job removing the glovebox, a lot of jiggling and swearing. Anyway, managed to remove the blower motor and this was inside. I'd say Sydney's hot weather over the last couple of months affected the adhesive and it's fallen in from up higher.
    Nov 2009
    Saved yourself $650 - that's a result!
    Mar 2014
    Melbourne, Vic
    Noisy AC
    Good stuff
