Fuel gauge intermittent issue
Hi all,
Every now and then, the fuel gauge needle on my 2012 VW cc v6 awd will not work. The needle stays at zero and the associated fuel reading on the digital readout (on dash) goes blank.
When this happens, I've found that turning the ignition on and off again has fixed the issue and the needle goes to its correct position.
Does anyone know what could be causing this? Is this a common issue? How can it be diagnosed and/or fixed?
Sent from my Pixel 2 XL using Tapatalk
- You may not post replies
- You may not edit your posts
Forum Rules
