Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Fatigue Detection System
    Mackay QLD
    Quote Originally Posted by Rawcpoppa View Post
    Thanks guys. I don't own a Passat CC so no way for me to check the manual. I was asking about it as I was wondering if it could be enabled via vcds/VAGCOM in other models as it all seems very software related in terms of how it works.
    It's also why I wanted to know what control module controls the feature.
    You are quite correct re being software related. I am researching the subject at present together with indirect TPMS option for my Tiguan.
    To activate the driver Fatigue and TPMS function you need to change the coding in the ABS module which inturn generates a "virtual module" called #4C. This module is like the old module 46 ie it exists in name but physically is part of the ABS module. This "module" controls all the settings in the MFD to set up the TPMS and driver fatigue options. Getting the correct coding to do this has been difficult as it varies from model to model as well as transmission engine RHD LHD etc.
    I have been collecting data from various Tiguan owners here in Australia Europe and the USA and from what I have seen on the Vortex VCDS threads. I am hoping to have something of substance in the next few weeks regarding the coding.
    Unfortunately there is no long coding helper in VCDS to help at this stage but I am sure at some stage Ross Tech will crack it. They appear to be very coy about the subject as I have raised a few posts about these "software options" but sadly no response from any of their team members re it's progress or how to recode the #3 ABS module to activate the functions.
    MY 21 T Cross 85TSI Life| Makena Turquoise | Driver Assist Package |
    Mods: VCDS tweaks |
    Trinidad and Tobago
    Is there anyway I can help? Do you need scans from a euro spec jetta? Steering wheel on the right as we drive on the left portion of the road.
    I have the indirect tyre pressure monitoring activated via retrofit. I enabled the tire pressure control module in the canbus controller then in the abs controller.
    Nov 2012
    Morwell, VIC
    However the Fatigue Detection works, I will say it seems pretty accurate. I had it pop up for the first time the other day, when I was dead tired (having got off an overnight flight). Luckily I didn't have far to travel.
    2013 CC 130TDI Night Blue Metallic with Driver Assistance Package, Park Assist 2, Walnut Trim and Ambient Lighting, Front Active Climate Control Seats, Towbar, and Dynaudio Premium Audio.
    My previous ride - 2005 Golf Comfortline DSG 2.0 TDI
    Mackay QLD
    Quote Originally Posted by GippsCC View Post
    Any chance you can send me an auto scan of your car. Highly likely your CC shares the same ABS module as the Tig
    Mods: VCDS tweaks |
    Nov 2012
    Morwell, VIC
    Quote Originally Posted by Bambazonke View Post
    Sure - ABS module auto-scan return:
    Address 03: ABS Brakes Labels: 3AA-614-109.clb
    Part No SW: 3AA 614 109 AR HW: 3AA 614 109 AR
    Component: J104 C2 450M V506 0030
    Revision: --H07--- Serial number: 00000006496474
    Coding: 0121788
    Shop #: WSC 05311 000 00000
    VCID: 7DDF1B252455A4F04AA
    No fault code found.
