Originally Posted by
Deep Blue
So you would use the Nulon product to clean the ASV (throttle body) and EGR valves when they're removed from the vehicle? What about the EGR cooler - doesn't that block as well with carbon/soot?
The Liqui Moly doesn't require removal of any parts apart from the air hose connecting to the ASV, but as you said, it's not terribly effective. If I use it then it will be just before I do an oil change as I suspect it will contaminate the oil.
I guess that's all academic though as I need to replace the temperature sensor first!
