Wiring harness for the bootlid has failed. It's a common fault on the CC.
Hi all,
Today I've hit a new problem with my CC. When I switch on the ignition, I receive error messages saying, left right reverse lights not working, left right fog lights not working, etc. I noticed brake lights are fine, as well the normal night lights. When I put the car into reverse, the RVC is black but I still see the steering lines. The boot won't open, I tried using the VW emblem, the button on the door and remote, nothing.
I'm wondering what could cause this? is there anything to check? a fuse maybe?
Many thanks.
Is there an emergency release ? Crawl in and pull it.
Here is some info on the broken wire harness: https://www.youtube.com/watch?v=xva3eoVgCq8
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
You'll have to drop the rear seats, crawl in, there's a black circular plastic cover on the boot lid, pop the cover off and you'll need to feel around for the latch which releases the boot
I have a complete harness if you are looking for one, and it has the RVC wiring also. I didn't realise it's a common fault, wondering if I should keep it for my CC![]()
