Results 1 to 4 of 4
Thread: Disc Rotor Size - V6 Passat CC
    Apr 2012
    Inner west, Sydney
    Hey guys,
    My brake Rotors starting to get a bit thin.
    Was going to order a new set but there are a bunch of different sizes.
    Anyone know which size was used in the MY09 Passat CC V6 3.6?
    May 2007
    You will need to confirm your PR codes. But here is a start;
    Front: 345mm (possibly the later model with the higher output V6) or 340mm
    Rear: 310mm (vented) or 282mm (solid)
    Assuming you will be doing Pads and Rotors, get yourself some ATE Ceramic Pads and matching ATE Rotors. You will not regret it...
    Info below from the ATE Website:
    Webshop
    Apr 2012
    Inner west, Sydney
    My PR codes indicate that I have 345mm rotors.
    Are pads specific to this size?
    Do I need some sort of wear sensor as well?
    Thanks!
    Jan 2015
    Kambra
    I have the same car, and yeah when I changed my discs, it was a PITA finding the right sizes.
    If it helps, mine were 345mm on the front and 310mm at the back.
    Pads were ATE 13.0470-7200 (which has a wear sensor wired into it) and ATE 13.0470-2887.2
    Of note,
    You will not be able to do the pads (properly) without a scan tool that can retract the pads for the back change.
    I got an OBDEleven to do this. If your not doing it yourself make sure the workshop knows about this.
    2009 CC 3.6
