Results 1 to 10 of 14
Thread: cost of fitting Towbar to passat 3cc v6 4motion?
    Jul 2010
    bracken ridge qld
    looking at getting a towbar fitted to above.was quoted $300 to fit plus $547 for kit.this sounds about right? opinions please.
    cheers
    warrick
    2011 3CC 3.6 V6. 19X8 CADWELL RIMS, K & N FILTER, EXHAUST TIPS,DBA SLOTTED FRONT DISCS,ATE CERAMIC FRONT PADS.
    Pacific Paradise QLD
    What year It seems about $1500 is the going rate for Passats like mine There was a big thread about it a few months ago with unhappy people with bodgy jobs of installation.
    Jul 2010
    bracken ridge qld
    yeah 2011 3CC. Towbars Australia was the mob going to do it.
    warrick
    Quote Originally Posted by warrick View Post
    warrick
    Module for lights etc is about $700 from what has been posted without the bar or fitting
    This is the thread I meant Not sure if your bumper is similar as this is about Passat wagon towbars
    Towbar - Poor workmanship
    Jul 2010
    bracken ridge qld
    heres the kit.may be some minor differences.
    Passat Coupe (CC and 4 motion)
    DESCRIPTION
    Capacity: 2200 kg Type: Medium Duty
    Ball Weight: 90 kg Fitting Time: 3 hrs
    European designed and supplied (ER)
    Meets Australian design rules
    ADR compliant quality towbar kit includes
    European clip lock removable type towball tongue to suit
    Fitting instructions
    All nuts, bolts and fitting hardware
    Universal ECU relay wiring kit
    Trailer connection plug as ordered
    Lifetime Warranty Certificate
    cost of fitting Towbar to passat 3cc v6 4motion?-towbar_zps1b1fd499-jpg
    Dec 2012
    Perth, Western Australia
    This is different to the swivelling unit like the one fitted if ordered as an option, yes? The one where its tucked away at rest, and electrically deployed when needed?
    Jul 2010
    bracken ridge qld
    i dont think this is like that.detachable tongue as per conventional towbar i would suspect.
    warrick
    Jul 2010
    bracken ridge qld
    booked in for weds next week to have this fitted,will report back after install.
    cheers
    warrick
    Jul 2010
    bracken ridge qld
    well had towbar fitted yesterday. Towbars Australia were excellent.done while i waited,about 2.5 hrs. very hassle free. the only thing is that the towbar itself is a bit unusual in style.with the tongue a rather suggestive shape,see pic post 5.the actual part of the towbar that is seen is a bit bulky/ different.the ease of tongue removal is good though,no bolts just a lever lock and load action.for what i want it does the job and a $1000 less than other quotes.certainly the team at Towbars Australia were a pleasure to deal with.
    cheers
    warrick
    Oct 2014
    Passat towbar
    Hi Warwick,
    Can you post some photos of the towbar as fitted to your Passat?
    Did they have to cut any of the bumper?
    Cheers!
    cheers
    warrick
