- Forum
- VW Passat
- CC
- Battery Replacement suggestions - After almost 12 years for OEM Varta!
I recall lots of backlash for VW claiming they're not reliable and super expensive to fix. Granted, compared to Honda, Toyota, Lexus and other superior Japanese cars, they're not as reliable or as cheap to maintain or repair.
But I've got 190,000km on our 2011 MY12 Passat CC V6 AWD. Still drives great and still powerful.
After almost 12 years, the OEM battery gave up. Looking into it - Varta 5K0 915 105K was not an easy to find replacement.
I took some measurements whilst in the boot, still connected (so wasn't exact) but it gave me some idea of what to look for.
Originally, I thought it must be an AGM battery considering the amazing life - it is not. Finding an equivalent was no easy task so I have listed the best alternatives in terms of value for money.
1. SuperCharge DIN85LH (MF88H) Battery – 900CCA - Great value for money as a direct, like for like match. 3 year warranty. Pricing varies from ~$300-$390
2. SuperCharge MF77H (DIN75LH) Battery – 780CCA. Cheaper again but not an exact size or spec match. 40 Month warranty. Pricing around $250-$310. This is shorter length and is the one I chose. It's a couple kg lighter as well.
To make it fit tight in the mounting bracket, I cut a piece of 35mm scrap wood and wedged it between the bottom plate and the battery before tightening the bracket down.
I'm sure we won't get 11.5 years out of it but I'm not sure how much longer I'll keep the car.
PS - If choosing another brand, ensure positive terminal is on the right side, and aim for dimensions 300-353mm Long x 175mm wide for mounting securely. Height is a matter of capacity. You can even go the cheaper MF77 which has 175mm height vs 190mm that the MF77H has along with a slight reduction in capacity and CCA
- You may not post replies
- You may not edit your posts
Forum Rules
