Most likely in your passenger footwell. Have a look underneath behind the glovebox and there should be a couple of thumb screws. Undo them and try to rmove the panel and there should be a box in there. If its similar to the golf (which it most likley is) the bottom of the box should slide off and the filter will fall out. Be careful as it will be full of leaves and dirt and junk!
this message thrown at you from the window of my flying Golf!
MY11 CW Golf RIntake, Tune, DP, DV+Superpro arms and ALKCustom 4" tipsTWM Short Shifter
