Results 1 to 2 of 2
Thread: Rear fog light wiring harness
    May 2010
    West Pennant Hills,NSW
    I have a 2010 CC. I have a warning on the dash about the rear left fog light not working.
    I have checked the globe and it is not faulty. I have heard that there is a possible fault in the wiring harness in the boot lid.
    Does anyone know where the cables run to from the light?
    Passat CC 2.0 TDi and loving it.
    Mar 2015
    NSW
    Have u had someone check that the glove isn't actually working when u put it in reverse? It may be that the bulb is not the factory spec & throwing an error -but still fine.
    I have fitted bright LED reverse lamps & get an error ALL the time. I have tried to eliminate the error using VCDS without success so I live with it.
