Results 1 to 9 of 9
Thread: Brakes fail CC 2012 3.6L
    Apr 2016
    moorebank
    Hello
    Today I was driving when the brake pedal went to mush and basically went to the floor.
    Braking was at maybe 10 to 20 percent. I parked it up for app 45min. I then drove home like nothing had ever happened.
    It was suggested that it could be the master cylinder, one of the pistons is getting stuck.
    Any ideas would be appreciated, and would it be safe to drive??
    Thanks
    George
    Mar 2014
    Melbourne, Vic
    Were you giving your brakes a really hard time? If so the brake fluid could of boiled.
    I would start by checking the fluid level to ensure there's no leaks, pretty sure the cc has a brake warning if he level gets low anyway. Haven't heard of a master cylinder failing but I guess it could be that also....
    Dec 2008
    Sydney/Canberra
    I wouldn't be driving it.
    Seems there may be some air in the lines that needs to be bled out.
    Any warnign lights on the dash? Does the car run rough? If it does, it could be an issue with the booster.
    Apr 2016
    moorebank
    No warning lights at all and no not giving it a hard time.
    I will check the fluid levels.
    thanks for the replies
    Apr 2016
    moorebank
    I just went to check the level of the fluid, it seemed that the cap was loose. Could this cause the spongy pedal?
    Dec 2008
    Sydney/Canberra
    No, because the system isn't pressurised at the reservoir.
    If anything, it'll just let moisture into the brake fluid and contaminate it.
    Dec 2014
    As Umai says, a loose cap will allow the brake fluid to absorb moisture. This in turn will lower the boiling point. But then you say you weren't using the brakes heavily.
    You'd expect air bubbles in the fluid to give you a permanently spongy pedal rather than an intermittent one. When was the fluid last flushed and replaced? You could consider bleeding the system completely using fresh brake fluid paying particular attention to any bubbles that might come out with the old fluid. If no air bubbles, you can eliminate that as a cause.
    Which then tends to bring you back to the previous suggestion of an intermittently faulty booster.
    Dec 2012
    Perth, Western Australia
    You haven't done any work underneath that could have possibly crimped/damaged lines? Long shot, I know.
    1981 Honda Civic hatch. Proper AUTO REVERSE cassette player. AM/FM with Stereo speakers. Four (yep, FOUR!) speed manual. Full cloth trim seats. HALOGEN lightbulbs! Factory options fitted: rear wipers and washer, "Go Fast" wheel covers & electric front windows.
    Apr 2016
    moorebank
    Hello
    Sorry for the late reply. No work was done to the car. Mechanic spoke to VW and they said they have never heard of an early replacement of the Master Cylinder, not common practice.
    So a flush with new fluid and a bleed was done. So far so good.
    Thanks to all for the replies.
    George
