Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Boot - Won't Go Up? 2009 VW Passat CC
    Apr 2011
    South Yarra
    Quote Originally Posted by MIG View Post
    Check some wreckers, not a common failure so parts on a wreck should be ok.
    Waiting to hear from Grant Walker Parts. Does anyone know a large VW wrecker in Melbourne (prepared to travel)?
    Mornington Peninsula, VIC
    City Wreckers Melbourne, they are in Footscray. Had 3-4 CCs last time I was there.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Apr 2011
    South Yarra
    Thanks.
    Apr 2011
    South Yarra
    Ordered the spring from Jollys Auto Parts Wreckers (only new ones I could see were from VW dealership and UK - too expensive and/or too long for delivery); ordered the fuel flap actuator (Topran) and strut (Stabilus) from Run Auto Parts.
    Apr 2011
    South Yarra
    Boot finished. The passenger side spring had broken - installed a new spring - got a new genuine VW one from EBay (UK). The passenger side strut, the only strut (acts as a damper so the boot doesn't fly open abruptly by virtue of the springs) was also knackered - installed a new Stabilus strut (purchased from Run Auto Parts). Next problem though is the fuel flap actuator - see my other post.
    Apr 2011
    South Yarra
    Managed to get a new VW Genuine spring on eBay from the UK - got here in 2 weeks and a fair bit cheaper than VW dealer here (5 weeks delivery from VW dealership) even with freight from UK included.
    Replaced broken spring and decided to anchor both springs (spring on each side of boot) at the least tension hole - consequently boot opens nice and smoothly now - doesn't fly open! The strut is only on the passenger side - it is clearly used as a damper - I guess for dampening (controlling) opening and closing. The original strut was shot and hardly dampening anything. Easy to remove/replace the strut (just a small flat blade screwdriver to lift the clips, don't remove, on each end so you can pull each end off). The strut was purchased from Run Auto Parts (good price) - Stabilus brand, and seems to be from the company that made the VW Genuine strut
    All in all - works excellently!
    Incidentally, saw a Youtube video where a guy uses a cable tie on each spring to hold a few spring turns tightly together - makes the boot lift look like an electric motor lift!
    Will install the fuel flap actuator soon when I get the spring.
    Apr 2011
    South Yarra
    Passenger-side tension spring broken! Looks like springs (on each side) lift the boot lid; moved both springs back a notch - boot opens nice and smoothly now - doesn't fly open like before! The strut was also gone - replaced it with a new one from Stabilus; the single strut acts like a damper.
    I noticed a plastic part 3C8 971 615B also fell off (not damaged) - looks like it might hold/support part of the wiring loom.
