Code:
Wednesday,27,May,2020,18:26:45:00007
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: License Plate:
Mileage: 88720km-55128mi Repair Order:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 02 03 08 09 10 13 14 15 16 17 19 22 25 36 42 44 46 4F 52
53 55 56 62 65 72
VIN: Mileage: 88720km-55128miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
14-Susp. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (BWS) Labels: 03H-906-032-BLV.clb
Part No SW: 03H 906 032 DQ HW: 03H 906 032 AB
Component: CC3.6-FSI-EU4 F 3490
Revision: 5GH04--- Serial number: VWZCZ000000000
Coding: 0000175
Shop #: WSC 22690 959 89399
VCID: 74E76AD117BB28EAC1-8020
1 Fault Found:
005717 - Please check DTC Memory of Auto. Distance Controller
P1655 - 004 - - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 88465 km
Time Indication: 0
Date: 2014.10.17
Time: 18:20:26
Freeze Frame:
RPM: 1628 /min
Load: 32.1 %
Speed: 81.0 km/h
Temperature: 86.0°C
Temperature: 17.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.843 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 012 F HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 1906
Revision: 04844002 Serial number: 00000810270086
Coding: 0000020
Shop #: WSC 05311 000 00000
VCID: 1325094D32758FD278-8046
No fault code found.
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 R HW: 3C0 614 109 R
Component: J104 C4 440 V3 0013
Revision: --025--- Serial number: 00000786375621
Coding: 0026015
Shop #: WSC 22690 959 72028
VCID: 2D51BFB5B41139224E-8078
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 5K0 907 044 AK HW: 5K0 907 044 AK
Component: Climatronic 130 0303
Revision: 00002001
Coding: 0000000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Climatronic A01001
ROD: EV_ClimaAutoBasis_VW46.rod
VCID: 74E76AD1DFBB28EAC1-8020
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000009102846
Coding: E3E68F8B00041A0047978F0017000000000AFB47E4400165170000000000
Shop #: WSC 05124 000 00000
VCID: 3365A9CD52356FD218-8066
Subsystem 1 - Part No: 3C8 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 151008 022 0602
Coding: 00046997
Shop #: WSC 05124
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 241108 054 0402
Coding: 00209133
Shop #: WSC 05124
Address 10: Park/Steer Assist (J791) Labels:. 1T0-919-475.clb
Part No SW: 1T0 919 475 L HW: 1T0 919 475
Component: PARKHILFE PLA H07 0021
Revision: -------- Serial number: 06530828700746
Coding: 101107
VCID: 4487FA11C79BD86AB1-8010
Address 13: Auto Dist. Reg Labels: 3C0-907-567.clb
Part No SW: 3C0 907 567 J HW: 3C0 907 567 J
Component: AC201 RDW A 031 0232
Revision: 00031000 Serial number: 00000000033432
Coding: 0010000
VCID: 326BACC9AD2F66DA13-8066
1 Fault Found:
00272 - Function Disabled due to Electromagnetic Interference
012 - Electrical Fault in Circuit - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101100
Fault Priority: 7
Fault Frequency: 3
Reset counter: 88
Mileage: 88526 km
Time Indication: 0
Date: 2014.10.17
Time: 19:20:53
Freeze Frame:
Count: 16
Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
Part No SW: 3C0 907 376 HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0069
Revision: 00000000 Serial number: 04110801910002
Coding: 030180
Shop #: WSC 05314 000 00000
VCID: 66C300999167CA7A4F-8032
1 Fault Found:
01319 - Control Module for Distance Control (J428)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 6
Reset counter: 88
Mileage: 88465 km
Time Indication: 0
Date: 2014.10.17
Time: 18:20:26
Freeze Frame:
Bin. Bits: 00000000 00000001
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 HW: 5N0 959 655
Component: J234__31G VW10 HI 1815
Revision: 19013000 Serial number: 0039BPPQ1MPI
Coding: 0012615
VCID: 7AFB44E935DF5E9A9B-802E
Subsystem 1 - Serial number: 6333FTS614583018
Subsystem 2 - Serial number: 6343FTS613293018
Subsystem 3 - Serial number: 6353ETS6GFROVVNJ
Subsystem 4 - Serial number: 6363ETS6PA1PVVNJ
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
