As a general rule, an isolated snippet of an autoscan is not very useful.
Please post the full autoscan for context.
Possibly something electrical such as low battery voltage or another consumer causing issues for the radar.
Hey guys,
today the ACC in my VW CC stopped working.
It gives ACC Error! on the dash, together with an exclamation mark.
I checked with VCDS and it gives the following:
Any idea what's going on?
Address 13: Auto Dist. Reg
1 Fault Found:
00272 - Function Disabled due to Electromagnetic Interference
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11101100
Fault Priority: 7
Fault Frequency: 3
Reset counter: 47
Mileage: 88465 km
Time Indication: 0
Date: 2054.14.02
Time: 18:20:26
Freeze Frame:
Count: 16
How do I fix it?
Thanks.
My apologies. I only saved that bit. I will do a full scan this afternoon and post the result.
The issue disappears after ignition restart and recurs after ~1-10km.
Code:Wednesday,27,May,2020,18:26:45:00007 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 18.9.0.2 Data version: 20180927 DS296.0 www.Ross-Tech.com VIN: License Plate: Mileage: 88720km-55128mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 3C-VW46 (3C0) Scan: 01 02 03 08 09 10 13 14 15 16 17 19 22 25 36 42 44 46 4F 52 53 55 56 62 65 72 VIN: Mileage: 88720km-55128miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 13-Auto Dist. Reg -- Status: Malfunction 0010 14-Susp. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 22-AWD -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 4F-Centr. Electr. II -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (BWS) Labels: 03H-906-032-BLV.clb Part No SW: 03H 906 032 DQ HW: 03H 906 032 AB Component: CC3.6-FSI-EU4 F 3490 Revision: 5GH04--- Serial number: VWZCZ000000000 Coding: 0000175 Shop #: WSC 22690 959 89399 VCID: 74E76AD117BB28EAC1-8020 1 Fault Found: 005717 - Please check DTC Memory of Auto. Distance Controller P1655 - 004 - - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 0 Fault Frequency: 6 Reset counter: 255 Mileage: 88465 km Time Indication: 0 Date: 2014.10.17 Time: 18:20:26 Freeze Frame: RPM: 1628 /min Load: 32.1 % Speed: 81.0 km/h Temperature: 86.0°C Temperature: 17.0°C Absolute Pres.: 1010.0 mbar Voltage: 13.843 V Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 02E-927-770.clb Part No SW: 02E 300 012 F HW: 02E 927 770 AJ Component: GSG DSG AG6 440 1906 Revision: 04844002 Serial number: 00000810270086 Coding: 0000020 Shop #: WSC 05311 000 00000 VCID: 1325094D32758FD278-8046 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb Part No SW: 3C0 614 109 R HW: 3C0 614 109 R Component: J104 C4 440 V3 0013 Revision: --025--- Serial number: 00000786375621 Coding: 0026015 Shop #: WSC 22690 959 72028 VCID: 2D51BFB5B41139224E-8078 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb Part No SW: 5K0 907 044 AK HW: 5K0 907 044 AK Component: Climatronic 130 0303 Revision: 00002001 Coding: 0000000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_Climatronic A01001 ROD: EV_ClimaAutoBasis_VW46.rod VCID: 74E76AD1DFBB28EAC1-8020 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl Part No SW: 3C8 937 049 E HW: 3C8 937 049 E Component: Bordnetz-SG H54 2602 Revision: 00H54000 Serial number: 00000009102846 Coding: E3E68F8B00041A0047978F0017000000000AFB47E4400165170000000000 Shop #: WSC 05124 000 00000 VCID: 3365A9CD52356FD218-8066 Subsystem 1 - Part No: 3C8 955 119 A Labels: 1KX-955-119.CLB Component: Wischer 151008 022 0602 Coding: 00046997 Shop #: WSC 05124 Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB Component: RLS 241108 054 0402 Coding: 00209133 Shop #: WSC 05124 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J791) Labels:. 1T0-919-475.clb Part No SW: 1T0 919 475 L HW: 1T0 919 475 Component: PARKHILFE PLA H07 0021 Revision: -------- Serial number: 06530828700746 Coding: 101107 Shop #: WSC 22690 959 72028 VCID: 4487FA11C79BD86AB1-8010 No fault code found. ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg Labels: 3C0-907-567.clb Part No SW: 3C0 907 567 J HW: 3C0 907 567 J Component: AC201 RDW A 031 0232 Revision: 00031000 Serial number: 00000000033432 Coding: 0010000 Shop #: WSC 05311 000 00000 VCID: 326BACC9AD2F66DA13-8066 1 Fault Found: 00272 - Function Disabled due to Electromagnetic Interference 012 - Electrical Fault in Circuit - Intermittent - MIL ON Freeze Frame: Fault Status: 10101100 Fault Priority: 7 Fault Frequency: 3 Reset counter: 88 Mileage: 88526 km Time Indication: 0 Date: 2014.10.17 Time: 19:20:53 Freeze Frame: Count: 16 ------------------------------------------------------------------------------- Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb Part No SW: 3C0 907 376 HW: 3C0 907 376 Component: DAEMPFUNGS-SG H07 0069 Revision: 00000000 Serial number: 04110801910002 Coding: 030180 Shop #: WSC 05314 000 00000 VCID: 66C300999167CA7A4F-8032 1 Fault Found: 01319 - Control Module for Distance Control (J428) 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 6 Fault Frequency: 6 Reset counter: 88 Mileage: 88465 km Time Indication: 0 Date: 2014.10.17 Time: 18:20:26 Freeze Frame: Bin. Bits: 00000000 00000001 ------------------------------------------------------------------------------- Address 15: Airbags Labels: 5N0-959-655.lbl Part No SW: 5N0 959 655 HW: 5N0 959 655 Component: J234__31G VW10 HI 1815 Revision: 19013000 Serial number: 0039BPPQ1MPI Coding: 0012615 Shop #: WSC 05311 000 00000 VCID: 7AFB44E935DF5E9A9B-802E Subsystem 1 - Serial number: 6333FTS614583018 Subsystem 2 - Serial number: 6343FTS613293018 Subsystem 3 - Serial number: 6353ETS6GFROVVNJ Subsystem 4 - Serial number: 6363ETS6PA1PVVNJ Subsystem 5 - Serial number: 00000000000000000 Subsystem 6 - Serial number: 00000000000000000 No fault code found.
Code:------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl Part No SW: 3C0 953 549 AJ HW: 3C0 953 549 AJ Component: J0527 0030 Revision: 00032000 Serial number: 3C5953507CR Coding: 0201821 Shop #: WSC 22690 959 72028 VCID: 74E76AD117BB28EAC1-8020 Subsystem 1 - Part No: 3C8 959 537 B Labels: 3C8-959-537.CLB Component: E221__MFL-TAP H4ÿ 0021 Coding: 00000227 Shop #: WSC 00000 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1 Part No SW: 3C8 920 870 B HW: 3C8 920 870 B Component: KOMBI H05 0107 Serial number: 00000000000000 Coding: 140F00 Shop #: WSC 22690 959 89399 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040 ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod VCID: 2A5BB4A94DFF2E1AAB-807E No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb Part No SW: 3C0 907 530 J HW: 3C0 907 951 Component: J533__Gateway H13 0152 Revision: H13 Serial number: 2900R08A268263 Coding: FDAFFF07000203009003 Shop #: WSC 22690 959 72028 VCID: 285F4EA19BF31C0ABD-807C No fault code found. ------------------------------------------------------------------------------- Address 22: AWD Labels: 0AY-907-554-V1.clb Part No SW: 0BS 907 554 A HW: 0BS 907 554 A Component: Haldex 4Motion 4013 Coding: 0000005 Shop #: WSC 00000 000 00000 VCID: 4487FA11079BD86AB1-8010 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 3C0-959-433-25.clb Part No SW: 3C0 959 433 AM HW: 3C0 959 433 AM Component: IMMO 052 0383 Revision: 00052000 Serial number: VWZCZ000000000 Shop #: WSC 131071 1023 2097151 VCID: 75E157D51CC131E2F6-8020 Subsystem 1 - Part No: 3C0 905 861 G Component: ELV 027 0380 3C0905861G ELV 027 0380 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl Part No SW: 3C8 959 760 HW: 3C8 959 760 Component: J810 0801 Revision: 00002000 Serial number: 00000000000000 Coding: 0000001 Shop #: WSC 05311 000 00000 VCID: 72EB6CC96DAF26DAD3-8026 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb Part No SW: 1T0 959 701 L HW: 1K0 959 793 P Component: J386 TUER-SG FT 1534 Revision: 71009005 Serial number: 00000689288926 Coding: 0005047 Shop #: WSC 05311 000 00000 VCID: 408FF6011383C44A95-8014 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb Part No: 1K0 909 144 E Component: EPS_ZFLS Kl. 212 2501 Revision: 00H15000 Shop #: WSC 02069 000 90108 VCID: 2C57B2B18F0B302A59-8078 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 3C0-959-433-46.clb Part No SW: 3C0 959 433 AM HW: 3C0 959 433 AM Component: KSG PQ46 RDK 052 0412 Revision: 00052000 Serial number: VWZCZ000000000 Coding: 00910A0001860E76360494157008DFCE105801 Shop #: WSC 05311 000 00000 VCID: 75E157D51CC131E2F6-8020 Subsystem 1 - Component: Sounder No Answer Subsystem 2 - Part No: 3C0 951 171 C Component: Neigungssensor 004 0611 Subsystem 3 - Part No: 3C0 951 171 C Component: Innenraumueberw.004 0611 1 Fault Found: 01134 - Alarm Horn (H12) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 47 Mileage: 88477 km Time Indication: 0 Date: 2014.10.17 Time: 18:30:34 ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II (J533_) Labels:. 1K0-907-532.clb Part No SW: 1K0 907 532 HW: 3C0 907 951 Component: J533__Gateway H13 0152 Revision: -------- Serial number: 2900R08A268263 Coding: 01010001 Shop #: WSC 22690 959 72028 VCID: 66C300999167CA7A4F-8032 1 Fault Found: 01512 - Control Module for Sliding Roof 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 47 Mileage: 88458 km Time Indication: 0 Date: 2014.10.17 Time: 18:13:15 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb Part No SW: 1T0 959 702 L HW: 1K0 959 792 P Component: J387 TUER-SG BT 1534 Revision: 71009005 Serial number: 00000512389004 Coding: 0005046 Shop #: WSC 05311 000 00000 VCID: 4189F3051889CD429A-8014 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 5N0-907-801.clb Part No SW: 3C8 907 801 A HW: 3C8 907 801 A Component: J540 EPB3 VW-10498 0003 Revision: 009 Serial number: 00000000201445 Coding: 0000057 Shop #: WSC 05311 000 08193 VCID: 285F4EA19BF31C0ABD-807C No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl Part No SW: 5M0 907 357 C HW: 5M0 907 357 C Component: AFS-Steuergeraet 0136 Revision: 00H04000 Serial number: Coding: 3526024 Shop #: WSC 05311 000 00000 VCID: 3467AAD1573B68EA01-8060 Subsystem 1 - Part No: 1K0 941 329 Labels: 3D0-941-329.CLB Component: AFS-Lst.-Modul l 0003 Coding: 00000053 Subsystem 2 - Part No: 1K0 941 329 Labels: 3D0-941-329.CLB Component: AFS-Lst.-Modul r 0003 Coding: 00000053 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb Part No SW: 6RF 035 187 E HW: 6RD 035 187 B Component: Radio 565 Y510 Revision: -------- Serial number: VWZZZ4J6204502 Coding: 0E000400040010 Shop #: WSC 00078 790 00101 VCID: 4B95D12DEAC5171270-801E No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb Part No SW: 3C8 959 703 B HW: 1K0 959 795 Q Component: J388 TUER-SG HL 0309 Revision: 43004101 Serial number: 00000000705035 Coding: 0000144 Shop #: WSC 05311 000 00000 VCID: 3169A3C5A8295DC26A-8064 No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl Part No SW: 3C0 959 433 AM HW: 3C0 959 433 AM Component: RDK 0453 Revision: 00052000 Serial number: VWZCZ000000000 Coding: 0161211 Shop #: WSC 131071 1023 2097151 VCID: 75E157D51CC131E2F6-8020 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb Part No SW: 3C8 959 704 B HW: 1K0 959 794 Q Component: J388 TUER-SG HR 0309 Revision: 43004101 Serial number: 00000000723869 Coding: 0000144 Shop #: WSC 05311 000 00000 VCID: 326BACC9AD2F66DA13-8066 No fault code found. End-------------------------(Elapsed Time: 02:56)--------------------------
Hmm voltage looks good.
I'd probably start with just unplugging the radar and checking the pins and connector for any corrosion or damage.
Clean with contact cleaner.
If it persists would have to look at the relay and fuse for the radar.
Sent from my SM-G960F using Tapatalk
You can just take the centre part of the grill out. No need to take the whole bumper off.
In fact you can just undo the top screws and the ones at the front and then pull it out enough while leaving the bottom connected and get access to it
Thanks. I was planning on removing the grill tomorrow but I went on a long drive today (~200km) and the cruise control worked flawlessly.
I remember now that the radar cruise stopped working the morning after a car wash. Maybe the car wash was too aggressive with the water jet and some water got into the connector, and it has now dried out?
