I have a coolant leak - only minor, but a leak nonetheless and it's making a mess.
I've identified where the leak is but can't find the part number and I've browsed so many websites looking for it. There is a coolant pipe that runs from the firewall (I'm assuming for the heater core?) to the rear of the engine block - directly under the intake pipe that runs from the air box to the intake.
Anyway, clamps are fine. The leak is actually coming from where the fitting mounts to the back of the engine. It appears to be a plastic piece, attached with 2 torx bolts, using a gasket or o-ring(?).
See picture attached to reference what I am trying to explain.
