Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 45
Thread: Sharkie's Up! Project
    Your links to the photos don't work Sharkie.
    Nov 2007
    Thanks, that was weird, did exactly the same again and now it seems to have worked
    Nov 2007
    BTW .... Any Up! owners out there wanting an intake for their Up! similar to this, PM me. Can do exactly the same again in either red, blue or black, all tubing, silicone, filter, bracket clamps etc included for about $150 shipped anywhere in Aus.
    Nov 2007
    Last upgrade before the Xmas ... I hated the stock running lights and went looking for a LED replacement. Brilliant white and no error codes, looks awesome.
    Before
    Sharkie's Up! Project-up-l1-jpg
    After
    Sharkie's Up! Project-up-l2-jpg
    Attachment 52529
    Also, new front struts and tools arrived to complete the lowered suspension job. Will be done over the holidays
    Nov 2007
    Suspension upgrade complete. About 30mm drop in the rear and 25mm in the front
    Sharkie's Up! Project-up-hr-suspension-fitted-jpg
    EDIT: It has settled in the front now to a 30mm drop too.
    Took the opportunity to do the front struts too with new Zachs units.
    Sharkie's Up! Project-up-shocks-jpg
    Looking good!!!
    Nov 2007
    Something that's not really well known (in Australia) or enabled on most Aussie Up!s is that there is an auto lock (and unlock feature). We take this for granted in most other VW's but it is disabled by default in Australia. I found the details online from the UK, so decided to try it on my Up!.
    Pre-change the necessary bits in 09-Central Electrics are unchecked.
    Sharkie's Up! Project-up-auto-lock-1-jpg
    Made the changes - Note: bits 3 and 4 needs to be checked.
    Sharkie's Up! Project-up-auto-lock-2-jpg
    And works like a dream. Auto locks over 15km/h and unlocks when you turn the car off and remove the key from the ignition.
    Call it a win.
    Nov 2007
    Also, I wanted to replace the vinyl/plastic/rubber steering wheel with the upspec edition's leather wheel and had to source 1 from Japan.
    Easy job to fit and makes a great upgrade.
    Sharkie's Up! Project-up-steer-old-jpg
    To:
    Sharkie's Up! Project-up-steer-new1-jpg
    Nov 2007
    Did the exhaust yesterday, this was a BIG job for such a little car ....
    This is a Milltek Exhaust made for the Up! GTI in the UK. Special import for me and the only 1 in Australia. Even HP was dubious about whether it would work.
    Pre
    Sharkie's Up! Project-up-pre-miltek-jpg
    Sharkie's Up! Project-up-miltek-parts-jpg
    Fitted up perfectly, needed a reducer to match the 2" (50mm) Milltek to the 40mm stock little pipe
    Sharkie's Up! Project-up-post-miltek-2-jpg
    This where the stock Up! bumper needs some cutting
    Sharkie's Up! Project-up-post-miltek-1-jpg
    and prepping
    Sharkie's Up! Project-up-rear-bumper-prep-jpg
    And painting
    Sharkie's Up! Project-up-rear-bumper-painted-jpg
    And done!
    Sharkie's Up! Project-up-miltek-done-1-jpgSharkie's Up! Project-up-miltek-done-2-jpg
    Sounds awesome
    Nice work! Was that just plasti-dip or did you go with something more permanent?
