Results 1 to 7 of 7
Thread: Bi Xenon headlights, DRL LED lights installation information
    Jun 2012
    Maroochydore, QLD
    VW Headlights Bi-Xenon LED Installation Process Stages
    STAGE1
    - pair of complete bi-Xenon Headlights
    - new BCM high line - $300+GST - needs to end in 087 for a correct operation
    - pair of adaptors harness - 90+GST - plugs on the car are different.
    - Labour for this stage is 6 hours and the lights work but they don't do auto levelling and they don't do cornering as from the factory.
    Stage 2 - AFS and Auto Levelling
    - AFS Module with harness- $200+GST
    - Auto-Levelling sensor and harness - $200 - this mounts on the rear axle of the car and has to be run to the glovebox, fusebox and to each individual headlight. You have to install wires all over these places in the car
    - Labour is 6 hours
    Stage 3 - Headlight washers / sprinklers
    - Headlights jets and sprinklers - price to be announced as it differes at around $350-$450
    - Harness - $100+GST
    - Labour - 4 hours - take off the bumper and install the sprinklers
    This is assuming the bumper has preparation for washers and does not need to be changed like on Golf 6.
    If it does not you can cut out the holes in the bumper or simply buy a new bumper.
    The Simple headlights are easy but if you want them to work as from the factory like this and have headlight washers it is is a big job and to make sure everything works properly we need the car for 3-4 days.
    This is how the lights are meant to work after the install: VW Golf 6 Bi-Xenon LED DRL AFS and auto-levelling test afte - YouTube
    If all 3 stages are completed in one go it can be done in approximately 12 hours - saving of 4 hours and it will cost you approximately $1200.
    If the corresponding wires are connected wrongly it might damage modules and replacement of them is the costly part.
    Adelaide hills, SA
    Good info thanks for posting it. I guess the point is; unless you're sure what you're doing don't attempt this as the DIY project.
    Link to complete thread.
    Jun 2012
    Maroochydore, QLD
    After the install:
    LED 100% brightness
    Main Beam + LED
    High Beam
    LED 50%+Indicator
    Jun 2012
    Maroochydore, QLD
    Please be advised that we have a new number in the workshop
    07 5479 5555
    HAPPY NEW YEAR from JKU Team
    May 2012
    Stupid question but how does one change the LED's between 50% and 100% or is the done through coding
    Jun 2012
    Maroochydore, QLD
    Its not a stupid one.
    Coding is the main thing
    When you have your indicator on, if the LEDS stay at 100% the indicator is almost non visible. Hence VW decided to either switch off the LEDS like in US&A or dim them to 50%
    Quote Originally Posted by Pickles View Post
    Jun 2012
    Maroochydore, QLD
    Good Day Volks,
    After months of development our IT dept came up with the Fresh Audi VW Upgrades Website
    Let us know what you think. Some of the functionality is in beta version.
    Attachment 7331
