The Volkswagen Golf MK5 GTI features a 2.0 litre turbocharged inline 4-cylinder petrol engine with Fuel Stratified Injection (FSI) direct-injection technology, which produces 147 kW. It is available in both 3-door and 5-door hatchback body shapes, and comes with a choice of either 6-speed manual or a 6-speed Direct-Shift Gearbox (DSG). It features four-wheel disc brakes, vented up front and solid out back, work with ABS and electronic brake-force distribution to slow things down. On the front you’ll find the big red calipers wrapped around the 345mm brake disc rotors while the back sports 253mm disc rotors.
NEED HELP CHOOSING THE RIGHT BRAKE PAD?
Bendix has specifically designed the Euro+ Brake Pad Kit to suit the 2003-2009 Volkswagen Golf MK5 GTi. This is a complete kit including pads, clips, shims, sensors as in equivalent OE kits so you can be assured that all components are the exact fit every time. Bendix is the only OE supplier to provide the innovative technology and quality required to produce Euro+ brake pads. These brake pads incorporate outstanding characteristics that result in consistently safe and quiet braking and long running performance without fading.
Front Brake Pads – Part No: DB1849
Fits: Volkswagen Golf Mk5 (2003-09) GTi 2.0 TMPI 1K 3 Door, 5 Door Hatch Jul 2005 – Sep 2009
Set consists of 1 Inner with Wear Sensor + Plain Inner + 2 Outer Pads
Rear Brake Pads – Part No DB1865
Set consists of 4 Pads
Available from your local Bendix stockist. Locate your nearest stockist here: www.bendix.com.au/stockists
