Bendix noise absorbing shims are designed to effectively prevent the transmission of vibration and noise from the brake pad by reducing the effect of the dynamic forces generated during braking. The material construction utilises advanced Fibre Impregnated Rubber Steel technology making the Shims impervious to a wide range of climates, salt, water and oil.
SEE THE DIFFERENCE FOR YOURSELF! A simple drop test shows how the noise absorption properties of the Bendix shim are superior to other shims on the market. Simply drop the shims one at- a-time onto a hard surface to hear how the sound of a Bendix shim compared to a standard shim produces a significantly softer, more muted sound. They are specifically designed by Bendix to each brake pad type to absorb vibration and reduce noise for the life of the brake pad. Mechanical lock technology provides full noise absorption even when the brake pad is under load. Bendix Noise Absorption Shims are tested in all weather and driving.
Links:
www.bendix.com.au
www.bendix.com.au/performance
