Now available (currently through special order) is the exciting replica reverse camera option below:
This unit works exactly the same as the OEM unit i.e. the camera pokes out when reverse gear is selected, and retracts when you select another gear. It also includes the necessary relay switch so all you need to do is connect it to a 12v power source, the easiest being the rear wiper. There is one wire which allows the wiper to return to park position even when power is removed, this would do fine for the permanent 12V supply for the camera unit, there is a discussion of this in this thread:
http://www.vwwatercooled.org.au/forums/f97/after-market-reversing-camera-32109-2.html
Note that this unit is a replica designed to be fitted to aftermarket units so it uses RCA for the camera signal - therefore it does NOT fit RCD or RNS 510. Maybe there is a converter out there that can convert the signal back to what the OEM units use, which I believe is RGB with a 12-pin (or was it 26-pin? something ridiculous for a camera input) cable, but you would have to look and make sure.
There is a good guide for installing the OEM RVC here:
OEM backup camera installation on mk6 VW Golf
With the replica camera there are no extra niggles with wiring looms as for the OEM! see below:
1. Grommet / plug for drain hose
2. drain hose
3. boot release switch
4. red wire - connect to permanent 12V
5. blue wire - connect to positive on reverse light
6. RCA input cable for camera signal
7. reverse camera hidden under badge!
Besides the removal & installation of the VW emblem, the installation of this camera is identical to any other aftermarket reverse camera, which is to say, much easier than OEM.
Specs for the camera:
This is a fair bit better than the array of reverse cam cheapies available on eBay. The camera is also shockproof and waterproof.
The unit comes with a one year warranty, the technician assures me that it is high quality and while I don't know how it compares with OEM, I have to say that if they wanted to cut corners, they can do a lot cheaper for a China manufactured product.
The price for these units will be
$290 shipped Australia wide.
