Results 1 to 8 of 8
Thread: YOUTUNE Diesel Performance Chip
    Aug 2008
    far South coast NSW
    Hello all, I have just bought A YOUTUNE Diesel Performance Chip for my MK5 2.0 TDI Golf. I tried to fit it but I was unable to locate the correct 2 plug sockets to connect the chip.The fitting instructions were not at all helpful as they did not show the Golf engine bay and where the connectors were located. Can any one e-mail a photo showing the location of the connectors please. Thanks in advance, Dennis. my e- mail address: vtec1100@activ8.net.au
    Have you tried contacting the manufacturer?
    YouTune: Diesel Performance Enhancing Chip
    I hope you didn't pay much for it...
    MKV Golf 2.0 TDI DSG Sportline. Just nice.
    Aug 2011
    vic
    Quote Originally Posted by stickshift3000 View Post
    Heh, 'interesting' website, has pictures on there where to install, interested to see if this thing actually makes a difference :S
    The ABN is registered to: Oasis Airconditioning
    :O
    melbourne
    hmmm not to rain on your parade but they're quoting a 30kw power increase for the polo 1.6tdi...
    given that the car has a dpf, i'm a little skeptical that a tuning box (as opposed to a proper remap) would be able to achieve that.
    post the same question in the diesels section, with a pic of your engine bay (well lit, of course), and see what the gurus in there say you need to unplug etc....
    good luck with it all!
    Jun 2011
    I would return it straight back. Here's a general idea why:
    Custom Tuning Myths and Facts | Malone Tuning Ltd.
    It's not much more than just a resistor, you can get $20 ones off ebay but those might "overskew" the ECU signal and cause ECU damage where these ones are more controlled. Instead of "multiply ECU signal by 1.5" these might offer a non-linear boost to the ECU signal depending on how much is coming through the ECU, but that's about all the difference (1.2 if signal > X, 1.3 if signal > Y). Definitely not a good idea if you care about your car, especially if you have a DPF...
    Rest assured, ALL these units can possibly do is increase fuel and boost requested by the ECU. And since it tricks the ECU signal to achieve this, if you are overfuelling or overboosting the ECU will have no idea until something goes broken. You won't see any of the extra soot coming out if you have a DPF either, but your DPF would sure know it...
    Agreed, cr@pola unit.
    Quote Originally Posted by DkN View Post
    Can they really alter boost levels? Which ecu parameter/s would it fool to do this?
    I was under the impression that boost wasn't altered by any ecu parameters, and never varies given myriad of operating conditions.
    I thought they only increase power by injecting more fuel.
    Jan 2008
    Sunshine Coast
    They can plug in to all sorts of places, really depends on what they are intercepting, and tricking. I've no knowledge of tuning boxes as they are indeed a crude improvement at best. That said, bang for buck, if done well, they are good things, and not all of them are a simple fuel resistor either lads, I've seen inside one mainline brand, and it was quite complex, with several processers ( albeit simple ones ).
    Contact the manufacturer, and google the unit and look for forum posts, especially in the UK. Those guys are light years ahead of us in respect to diesel tuning, and I learn a lot from the UK forums.
    All that said, back in the day I put an ebay resistor on my ex's PT cruiser and the power result was very noticable!
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by Buller_Scott View Post
    Given that the 6R TDi has been detuned quite a lot, almost certainly to protect the DPF, I'd say that power boost was possible. It will also probably kill the DPF in short order (and cause frequent regens before that) due to the overfuelling that these things tend to cause.
    MkV Golf would be OK but I seriously doubt the "no black smoke" claim.
