Results 1 to 7 of 7
Thread: Is it worth ceramic coating a DP
    Oct 2012
    I'm getting ready for the next stage of mods and am looking at a downpipe. Is it worth getting the pipe ceramic coated or am I just wasting my money?
    Daniel
    HIS - MY11 VW Golf R - Leather seats, Sunroof - DSG - 19" Talladegas - Black Headlights - Dynaudio - ACC - APR Stage 1 - Maniacs DSG Paddle Extension - Volant CAI -
    HERS - MY13 VW Passat Alltrack - Sports Pack - Panoramic Sunroof -
    Dec 2012
    Sutherland Shire, Sydney
    Trouble is, there are three different ceramic coatings
    The turbo coating application (for high temperature) is also the least durable
    For racing and for where you have under bonnet temperature problems, yes, use it, otherwise, not much benefit
    Gosford Central Coast NSW
    From and engineering point of view, on a road car, it is just a waste of money. Its really one of those things that race engineers use to get another 0.1% when all the 0.1%'s add up to something that gives a competitive edge, but unless your in that scenario it doesnt make sense. However, you might want to do it for reasons other than performance.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Dont bother - i coated a dump pipe about 18 months ago for my Golf R (cost about $250 for the best coating) and within months it was chipping off/flaking off and there was zero performance difference.
    Oct 2012
    Thanks for the feedback. Saved me some $$$
    Daniel
    We used to supply the TurboXS downpipes that we co-designed with the proper Cerakote coating as an option and they seem to hold up very well none I've seen have flaked so far but since early this year I've taken over fabrication of everything and am now having it made at Walker we've had a good look at things and decided it just wasn't worth it. If your using decent thickness true stainless then its not going to do much even if it does lower under bonnet temps a bit.
    Feb 2010
    Auckland NZ
    What about just heat wrapping?
