Can't be done with VAG-COM as far as I'm aware as you actually need to modify your Eeprom which the above can't do.
You need either the kvw100 oneshot flash tool which Fuzion sells (not sure if he still has any) or you need the VAG-TACHO software and cable.
http://www.szkvw.com/
http://www.vagproduct.com/
Cheers,
Trent
