Results 1 to 10 of 13
Thread: windows and key fobs
    Dec 2008
    perth
    righto, sorry to do this---- but,
    ive got vag-com. ive got the cable.
    ive also got the mk4 r32 to mod-----i just dont have the code to make the windows go up n down via remote!
    please, someone give me a straight answer, ive been scanning forums for two days now and know how to do every vag model but mine!! argh!!!
    please help! thanks!
    black mkIV .:R32 #001/200
    04 black new beetle turbo
    matt black 1970 beetle- low n slow!
    Dec 2007
    Brisbane, Southside...
    Can't be done with VAG-COM as far as I'm aware as you actually need to modify your Eeprom which the above can't do.
    You need either the kvw100 oneshot flash tool which Fuzion sells (not sure if he still has any) or you need the VAG-TACHO software and cable.
    http://www.szkvw.com/
    http://www.vagproduct.com/
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    I fettled my 2000 S3 to shut the windows the other day.
    Channel 35 I think for central locking. Then coding. A window opens up and you add the number in the box, for the feature you want, to the existing code. Mine was 16200 IIRC and to close the windows on the button was +512 I think. So you put 16712 and press 'do it'.
    Job done.
    If that's not it have a look at Channel 46. Central convenience
    Aug 2007
    Yeah i was sure you can too mate, i know the Pog you cant.
    Jmac
    Alba European
    Aug 2007
    Perth WA
    I thought the VW VAG codes were just binary 1 or 0 for each option on the interface, not a cumulative decimal number as seems to be the case on Audis.
    Uberwagen, I did mine using a kvw100.
    Balkanac has done his R too, he has a V-Checker I think so he may be able to help!
    '04 BMP MkIV R32 #144
    search getnew
    Dec 2007
    Quote Originally Posted by geoff_gti View Post
    Have a look here. Pretty sure Balkanac has VAG-Tacho.
    It's a feature in the MkV Golf which can be enabled disabled via VAG-COM but I'm still pretty sure you can't do it on the MkIVs which is why the kvw100 was made. But hey somebody prove me wrong
    Cheers,
    Trent
    Aug 2007
    Perth WA
    Quote Originally Posted by Treza360 View Post
    Cheers,
    Trent
    fixed ya link
    i'd like Distance to Empty too, as per that thread, but not unless someone has an easy option like a 1 or 0 to turn it off - wouldn't bother if it means manual programming lol. I often just flick my parkers on for the reason of getting the dash lights too otherwise it can be a bit dark to see with sunnies on. So many hidden options...
    search getnew
    Feb 2007
    Perth, WA
    Can u make it so it flashes up a message on the dash when u start the car?
    "L0L HaX0R!!!!!" perhaps?
    Aug 2007
    Perth WA
    Quote Originally Posted by MattyT View Post
    probably! you'd have to write in hex though i bet haha
    search getnew
    Aug 2007
    If you have VDO you can have a Welcome on the dash no worries, but yeah a hex adjjstment is reqd
    Jmac
    Alba European
