DNA Tuning (Australia)
Results 11 to 20 of 32
Thread: Win a go pro with Tarmac!!
    Oct 2011
    Quote Originally Posted by sVWatt View Post
    "Real data?" - be nice to see what the real data actually looked like. Always thought that style should at least match function - in this case why not 'stylise' the key to the graph so the colours at least match.
    On a serious note though - what are typical values after the modification? I think APR claim 189kW on a stage 1 mod...
    Excellent spotting on the colours not matching. Guess i was too busy to pick that up. Surely it is obvious though that our results are the green lines though? I will fix the colour miss match up.
    This is the legit original dyno graph. As Tim states below. You need to make the graphs look pretty for the average consumer and in brochures that are handed out to the public. The results are the same.
    Quote Originally Posted by Tim View Post
    The graphs are stylised because real data isnt pretty enough for the average consumer
    Oct 2011
    I should also mention APR is an American company. I have never seen there claimed results make what they say. They also claim power at the engine. Not at the wheels on a roller dyno. Cheap Hub dynos dont count when 95% of the industry uses roller dynos.
    Point Cook, Vic
    most tuners should see between 160-170kw at the wheels for a car with intake and downpipe so the figure above is up there. It does vary a lot from dyno to dyno though so who knows. The figures arent easy to compare unless theyre side by side.
    If you minus the drivetrain loss from 189kw its about 155ish at the wheels.
    FOLLOW US ON FACEBOOK
    Oct 2011
    This^ This is how competitors in the industry get along. 95% of the time Tim and i will agree with each others comments. Different state, different company. Different products.
    Jun 2009
    Quote Originally Posted by Tarmac View Post
    Just a thought, maybe it would be a good idea to advertise the power rating as "at the wheels."
    Also, does BPS run an AWD dyno
    Oct 2011
    Quote Originally Posted by team_v View Post
    Good idea Clay.
    The graph was more done for a brochure to quickly and easily show the gains that come from our tunes.
    Yes BPS have an AWD dyno. So FWD cars are measure at the front wheels and AWD cars at all 4 wheels.
    Awesome.
    Yes just being a picky marketer
    I love the idea of your touch pad. Does it plug into the port under the steering wheel?
    And, when it reverts to standard (dealer service friendly) is it a bit-perfect copy of the original individual car scan?
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
    Oct 2011
    Awesome.
    haha, someone had to do it.
    Your spot on. The OBDII port on the right under the steering wheel. When you switch back to the factory tune it 100% loads and reverts back to the factory tune from VW.
    Mar 2013
    Brisvagas
    Re: Win a go pro with Tarmac!!
    Quote Originally Posted by Tob35 View Post
    These would still require a bench tune first wouldn't they?
    So.... will this infact tune a MK6 GTI straight from the OBD straight up? Or do you have to crack open the ECU to enable.
    Oct 2011
    We are a few weeks away from being able to do it purely via OBDII
