![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
Peter Jones
Slowly understanding this now.
Dizzy spacer will be required. I think I'll make one out of the 2E distributor. I don't need - it'll be useless without it's gear anyway.
Looks like I also need a block off plate for the breather box. Shouldn't be too hard to fab one up, this also mounts up the WUR.
The timing belt has me a little thrown at the moment. The 2.0 one is a couple of teeth longer than the 1.8. So if I put the 1.8 head on which belt will suit? Some people mention using the 1.8 crank pulley?
I'd like to try and get a serpentine belt setup working on this motor, think I've got that all figured out, except for what length belt it finally going to take.
2E motors seem cheap and bountiful, I'm only considering this as a stop gap until next year when I'd like to scratch build something.
I have a $50 Japanese 2E sitting here so I figure I'll I'll strip it to the short block, replace all the gaskets and bolt it up under the 1.8 GX K-Jet head for now. couldn't possibly be any worse than the GX is now!
Pete
