DNA Tuning (Australia)
Results 1 to 10 of 10
Thread: Where is my Mass Air Flow/Meter located?
    Dec 2007
    Hi All,
    Could somebody tell me where my Mass Air Flow/Meter would be located in the pic below?
    Jan 2007
    I'm not entirely sure about the newer models but it should be in the throttle body, at least mine is ...
    Dec 2006
    Kilsyth, VIC
    If I had to guess I would say it's that little bit sticking out of the air pipe behind the oil cap, but then I really am guessing.
    Aug 2007
    Quote Originally Posted by The_Hawk View Post
    Thats one of the crankcase breather pipes. Not entirely sure because i cant see the entire engine but it may be running a MAP sensor intstead. Whats the engine code of your car? Tell me and ill be able to answer your question.
    Dec 2007
    The engine code is BSE
    Dec 2007
    Quote Originally Posted by VW Caddy View Post
    To add to that.............its a 2005 model 1.6L VW Caddy.
    Aug 2007
    One sec, gotta wait for the laptop to boot up again!
    Aug 2007
    Ok. Its a map sensor that is also the air intake temp sensor and its located on the top of the intake manifold to the left of the oil filler neck.
    Dec 2007
    Quote Originally Posted by FknDubbin View Post
    Thanks for that FknDubbin. My question now is............if i were to replace my air filter with a K&N short ram system, would i have all those 'oil' related problems seeing as I have a MAP rather than a MAF?
    Aug 2007
    You shouldnt. Dont oil the filter too much. Thats never good for any type of sensor. The MAP sensor will just measure manifold pressure. Theres no metered air passing through any wires to foul it up.
