I'm not entirely sure about the newer models but it should be in the throttle body, at least mine is ...
Hi All,
Could somebody tell me where my Mass Air Flow/Meter would be located in the pic below?
If I had to guess I would say it's that little bit sticking out of the air pipe behind the oil cap, but then I really am guessing.
The engine code is BSE
Ok. Its a map sensor that is also the air intake temp sensor and its located on the top of the intake manifold to the left of the oil filler neck.
You shouldnt. Dont oil the filter too much. Thats never good for any type of sensor. The MAP sensor will just measure manifold pressure. Theres no metered air passing through any wires to foul it up.
