Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: What should i do first
    burnie,tas
    You need to hang the pedal off your column if you are lucky, or change the pedal box.
    Hopefully it has a manual steering rack with the bracket you need on it otherwise you need to change that too.
    You need a different throttle cable that goes straight to the carby, not via the auto like on an automatic.
    Finally you need a 4 or 5 speed gearbox. Make sure you get the mount with it as you will need it.
    Finally shifter and linkages and you are done.
    Its not that hard and its worth it.
    i got my hands on a 4 speed 77 golf for biz and i was reading my manual and it said that the fly wheel is heat shrunk on
    Camden, Sydney
    Ring gear is heat shrunk onto the flywheel on the manual flywheel, but both aut and manual flywheels will just unbolt.
    burnie,tas
    thanks alot i look at the car at my parts car and it better body than my one now and it a nice yellow colour photo will be on my web site once i get some pic
