It will read current and historic codes up until the previous time the fault codes were erased.
Hi All
A bit of a noob question which I've been unable to find a definitive answer to.
Would using a VAGCOM cable allow me to get a read out of all the historical faults generated on my car? Specifically when oil warnings occurred, blinker faults etc... Or is only current faults?
Thanks in advance
GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
And shows the mileage when faults occurred.
Looks like this:
Code:Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb Part No SW: 1K0 937 084 B HW: 1K0 937 084 B Component: BCM PQ35 B 103 0537 Revision: 00103 AC Coding: 40180A3AE03518C0C4080080310000E441710088537D8D60648000200000 Shop #: WSC 01357 011 00200 VCID: 2D7FD864CD81 Part No: 1K2 955 119 E Component: Wischer 27050 21 0501 Coding: 009795 Part No: 1K0 955 559 AH Component: RLS 090609 05 54 0402 Coding: 0730AD 2 Faults Found: 01520 - Rain and Light Recognition Sensor (G397) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 8 Reset counter: 172 Mileage: 21342 km Time Indication: 0 Freeze Frame: Term 15 Off Voltage: 12.75 V OFF ON Term 50 Off OFF OFF 01520 - Rain and Light Recognition Sensor (G397) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 4 Reset counter: 175 Mileage: 24586 km Time Indication: 0 Date: 2016.14.21 Time: 16:18:18 Freeze Frame: Term 15 On Voltage: 14.10 V ON ON Term 50 Off OFF OFF
Thanks for the information. It looks like this should give me what I need.
Next question, would anyone with this cable be available in Sydney to assist? I posted a request on another thread, VAG-COM Scanning but havent received any offers. Financial compensation for your time is open for discussion.
Thanks again..
Faults can disappear by themselves as well depending on the fault severity, if they don't happen again for a number of trips. This is the reset counter.
I have VCDS Cable.
Where are you located?
\( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
