Results 1 to 8 of 8
Thread: What information will using a VAGCOM cable show?
    Hi All
    A bit of a noob question which I've been unable to find a definitive answer to.
    Would using a VAGCOM cable allow me to get a read out of all the historical faults generated on my car? Specifically when oil warnings occurred, blinker faults etc... Or is only current faults?
    Thanks in advance
    Apr 2009
    It will read current and historic codes up until the previous time the fault codes were erased.
    GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
    Apr 2010
    And shows the mileage when faults occurred.
    Looks like this:
    Code:
    Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
       Part No SW: 1K0 937 084 B    HW: 1K0 937 084 B
       Component: BCM PQ35  B   103 0537
       Revision: 00103 AC
       Coding: 40180A3AE03518C0C4080080310000E441710088537D8D60648000200000
       Shop #: WSC 01357 011 00200
       VCID: 2D7FD864CD81
       Part No: 1K2 955 119 E
       Component: Wischer 27050  21  0501
       Coding: 009795
       Part No: 1K0 955 559 AH
       Component: RLS 090609 05  54  0402
       Coding: 0730AD
    2 Faults Found:
    01520 - Rain and Light Recognition Sensor (G397)
                004 - No Signal/Communication - Intermittent
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 2
                        Fault Frequency: 8
                        Reset counter: 172
                        Mileage: 21342 km
                        Time Indication: 0
                 Freeze Frame:
                            Term 15 Off
                        Voltage: 12.75 V
                            OFF
                            ON
                            Term 50 Off
                            OFF
                            OFF
                008 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 2
                        Fault Frequency: 4
                        Reset counter: 175
                        Mileage: 24586 km
                        Time Indication: 0
                        Date: 2016.14.21
                        Time: 16:18:18
                 Freeze Frame:
                            Term 15 On
                        Voltage: 14.10 V
                            ON
                            ON
                            Term 50 Off
                            OFF
                            OFF
    Thanks for the information. It looks like this should give me what I need.
    Next question, would anyone with this cable be available in Sydney to assist? I posted a request on another thread, VAG-COM Scanning but havent received any offers. Financial compensation for your time is open for discussion.
    Thanks again..
    Apr 2010
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by sorcam View Post
    Just remember the key point:
    Quote Originally Posted by Ozram View Post
    Meaning if the fault has not reoccured it will not show up if it was cleared. To be clear you don't get a history of every fault ever, just the "current" ones.
    Apr 2010
    Faults can disappear by themselves as well depending on the fault severity, if they don't happen again for a number of trips. This is the reset counter.
    Nov 2005
    Sydney NSW
    I have VCDS Cable.
    Where are you located?
    \( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
    ((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
