DNA Tuning (Australia)
Results 1 to 9 of 9
Thread: What is the difference between 96Kw & 128Kw 2.5 TDI Vans ??..
    May 2009
    Please Enter Location
    Smile What is the difference between 96Kw & 128Kw 2.5 TDI Vans ??..
    Hi All,
    I have been searching through these pages to research the difference between the 96Kw & 128Kw 2.5 TDI Transporter vans. I am currently looking at buying a '06 96Kw 2.5ltr TDI Transporter as a upgrade for the family as the kids get bigger. I have reading all about the different model variants (which is a few) and can't seem to find any reference to the output difference between the two motors. From what I can see they are the same motor both 2.5ltr TDI but one has a higher output rating than the other.
    Is the differnce an actual mechanical difference in the motor/driveline or is it all in the ECU/tunning side. If it is in the ECU does anyone know what is required to upgrade the 96kw to a 128Kw or more to the point can it be done?. If so who/where and rough cost.
    Has anyone out there driven both that could give me an opinion of the difference, the reason I ask is it will be moving 2 Adults and 7 kids around the countryside with all the usual gear, from all the reading I have done the VW van is the way to go but I am still trying to find one to test drive.
    Any and all knowledge or opinions would be greatly appreciated as I know very little about the VW side of the fence as I have not previously owned one.
    Kind Regards
    Vwnewby.
    There are mechanical differences between these models, but also drivetrain differences. Different clutch, gearbox, diff ratio's & gear sets. So no, it's not just software!
    We have modified dozens of these (both engine forms), there is a lot to consider before you purchase on what you will require total power wise (or more likely torque).
    I have a 128kw & for the extra bucks I would go with the bigger output any day. I have towed 3 ton (braked) car trailer & car behind it up through the mountains & it was effortless. My friend following us in a V8 twin turbo TDI cruiser couldn't believe it!
    You can see from graphs your expected modified outputs, 0-100 times etc.
    hopefully this will help out
    Dec 2008
    Perth, WA
    Stock, 0-100, 15.3 seconds?
    Mar 2008
    Quote Originally Posted by kryten2001 View Post
    Compared to a 240kw GTI getting 7.1s
    Dec 2008
    Perth, WA
    Quote Originally Posted by AusScare View Post
    7.1? Left the handbrake on?
    Mar 2008
    Dunno, you tell me.
    I was getting 14.2's using a Dynolicious. 2.6 second 60' and 7.1 second (!!!) 0-100.. All because of monster wheelspin through all first 3 gears. Would have lost significant time.
    Dec 2008
    Perth, WA
    Dunno, you tell me.
    Getting quicker.
    Mar 2006
    brisbane
    I drove golf loons tdi van, i presume it has the larger motor as i was almost keeping up with his 20vt and had a friend in an e36 eating my dust..
    not sure if this helps you but i have never before been in a van that i would describe as 'fast!'
    Jan 2007
    South Australia
    0-100km/h times could include half a load 500KG plus a driver and fuel unless VW state otherwise.
    - Ben
    1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
    2008 Jetta 2.0L FSI
