Originally Posted by
golfworx
Not a bad choice Pete.
You can still go a fair bit bigger even with K-Jet.
The Autotech 270 is a tiny bit bigger & I never had any trouble's with it on K-Jet & can recommend this to anyone.
I just ordered a 276 cam.
It's the second largest hyd. I could find & should be pretty lumpy. 10whp increase they reckon & power come's on strong from 4000rpm.
Hopefully have it next week & have it installed next weekend. Will give an update how it is.
On the flip side, you should try & upgrade your K-Jet to a Volvo 240 setup with a Adui throttle body.
The improvement is fairly substantial & is easily noticable.
One other thing you mentioned in your PI post is about revving your engine into to the fuel gauge.
I can safely say this, as I had a stock GX at one time & the problem is, it's not making anymore power after 5500rpm, so your just flogging a dead horse revving it that hard.
The 268 will make nice power, but still revving it this hard is a waist.
I revved my 270 to 6700rpm cleanly & it was just starting to nose over at the end of Symmond's Plain's at a indicated 195km/h with a stock Diesel 4 speed.
I'd only rev it to 6200rpm between gear shift's & let the improve bottom end response & torque pull through the gear's.
