When it comes to building engine's, I like to keep detailed record's of what get's done & what goes into them.
The engine was rebuilt in 98, so it was a far while ago now. Has clocked up over 370+k with only a headgasket failure.
I wouldn't suggest skimming the head super thin to raise the CR, as this can cause mixture & ignition problem's.
I ended up fitting new piston's which had a smaller volume & higher deck height.
I should have posted this up before to save confusion
Here's all the dismantled & assemble spec's
GX Engine
Bore - 81mm
Stroke - 86.4mm
Swept Volume Per Cylinder – 445.398cc
Engine Capacity - 1781.582cc
As Dismantled/As Assembled
DeckDeck height -1.00mm/0.60mm
Head gasket height -1.65mm/1.65mm
Piston Crown Volume -17.69cc/11.27cc
Deck Height + Gasket Volume -13.6609cc/11.5989cc
Cyl. Head Volume - 30.00cc/ 30.00cc
Compression Ratio
Piston Crown Volume - 17.69cc/11.27cc
Deck Height + Gasket Volume - +13.6609cc/+11.5989cc
Cyl. Head Volume - +30.00cc/+30.00cc
Total Combustion Chamber Volume =61.3509/=52.8689
Swept Volume - 445.398/445.398
=506.7489/=498.2669
Total Combustion Chamber Volume - +61.3509/+52.8689
Compression Ratio = 8.2598:1/9.4246:1
Cam Specs – Stock GX
In Opens 15°BTDC
In Closes 55°ABDC
Ex Opens 55°BBDC
Ex Closes 15°ATDC
Duration In + Ex 250°
Lift @ Lobe .360”
As you can see, a Autotech 270 is a much bigger cam.
If you just going to fit a Hydraulic G Grind, I wouldn't bother about HD valve spring's, just lifter's. But on the other hand, if the engine has had a hard time for most of it's life, new spring's wouldn't be such a bad idea.
Just out of interest sake, the Autotech 270 is $129.95US. They should post to OZ.
