Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: water/meth injection
    Hi guys, not sure if this is the right section, but couldn't find too much in the search section.
    anyways.
    i'm curious to know if anyone here uses water/meth injection?
    i'm thinking about it, not really for the performance gains (would be a bonus though) but for milage and cost
    is the an decrease in L/100km?
    if so, is the cost of the water/meth and fuel used cheaper in general than just using fuel?
    and how much water/meth do you go through?
    Thanks
    99' TT Quattro 225: 3A Racing Pod, GFB Hybrid Respons TMS BOV, 42DD Turbo Back Exhaust, Magnaflow Muffler, 4bar fpr, REVO Stage 2, APR Inlet Hose...Alpine Type R Front Splits and Rear Components, Alpine CDA-117E Headunit, Kicker ZX700.5 ZX, Kicker CRV 12", 93' Bionic Blue Nissan Skyline R33 GTST sold, 02' Gun Metal Grey Nissan Silvia Spec S GT sold
    Jan 2009
    blankedy
    I thing the cost of installation and then cost of meth would outweigh any fuel savings.
    I've only heard of it being used in high boost applications.
    Jan 2008
    Sunshine Coast
    If you own a chook farm and distill your own methanol, you'd save money. Otherwise in a petrol car it's a mild power adder and mainly a chemical intercooler. In a diesel it's additional fuel and it's possible to get a fuel saving, but I reckon also unlikely.
    Methanol is an accumulative poison and rather smelly, so it's not a simple thing to play with. It's the component in moonshine that makes you go blind, amongst other things, and is absorbed through your skin.
    The progressive kits that could possibly save fuel are the expensive ones, my Snow kit was about $1k landed. That's a lot of fuel.....
    Trust the turbo back is going ok!
    Apr 2006
    VW Race HQ - Sydney
    If your looking at fuel savings then you need to run straight water injection . That way you can use a lower octane fuel and you wont suffer from pre-ignition or knocking . The savings arent huge though , couple of dollars every tank
    Bug_racer supports the rebellion of the euro revolution
    Sep 2007
    Perth
    See the recent post by J Robbo under Cars of Tigersoft - he mentions the Snow Performance methanol injection on his E39 supercharged M5.
    http://www.vwwatercooled.org.au/foru...ion-74566.html
    2001 Bora 4Motion from new, upgraded Haldex controller, Bilsteins, Milltek
    2014 Golf 90TSi, Comfortline, manual
    Apr 2011
    Rochedale, QLD
    I thought about going down the path of water/meth but i heard too many horror stories of blown engines and even witnessed a burnt out bmw 135 caused from water/meth. From what i hear you need to make sure you tank is always full, if you run it empty with the foot flat it could end in disaster.
    Im still curious to see what other people say but.
    Jan 2008
    Sunshine Coast
    At 50% or below water methanol mix isn't flamable. People think more is better, and yep, it becomes quite dangerous above that ratio. The only way water meth would damage your engine is if you had a tune specific to the water meth, and then when it runs out, you don't have the additional cooling. It's dead simple to add a float switch to the tank, you have to mount them about 2cm high anyway, and it certainly lets you know when you are getting down. I think if an injection kit is laid over a normal ECU tune, then it's fine to run it dry.
    The biggest problem is keeping it watertight with no leaks, as it's very smelly and again, quite poisionous.
    Jun 2006
    Orange NSW
    Excellent tech info, Greg.
    Methanol on it's own burns cooler than petrol. You can also generally run 30% either side of stoich and not suffer any issues. It's extremely forgiving. Anyone blaming water/meth for an engine failure is either misguided or lying.
    I wouldn't consider it ridiculously poisonous. We've gotten enough of it on ourselves over the years.. Any speedway racer or drag racer will attest to it being relatively safe. It's only truly harmful if you ingest it or take baths in it for extended periods.
    If you're worried about methanol, read the MSDS on nitromethane...
    Jan 2008
    Sunshine Coast
    Yeah but Drag Racers can be blind Preeny, you just put them dead straight in staging and tell them not to turn for several seconds.....
    Jun 2006
    Orange NSW
    Quote Originally Posted by Greg Roles View Post
    Hahaha. I'm not going to bite.
    Have you ever read the MSDS (now called an SDS, so I found out yesterday) on Diesel? Yikes!! Methanol's good, clean living compared to that ****! Haha.
