Originally Posted by
Greg Roles
...Diesels don't have ANY concerns as per Petrol, as they are basically always "pinging" and running lean. When you advance timing in a petrol car with a water / meth setup, you run the risk of preignition should the tank run dry. If you can't account for that with some sort of failsafe, then you do indeed deserve to destroy your engine. Similarily if you have zero chemistry knowledge, or simple intelligence at all for that matter, you should not be messing around with flammable liquids in the first place. It's a Darwinian thing.
In a diesel methanol acts as extra fuel, and there have been runs by Snow in the USA of a 50/50 mix adding approx 30hp and 50nm to a 2.0 Jetta TDI. Certainly feels like that on my car. Going beyond 50/50 does liberate a bit more power, but not as much as you would think, law of diminishing returns. Also becomes flamable...
So its basically the same as diesel/LPG, then?
I.E. When the bottles empty you're back to 60% efficiency instead of 80-90?
Sorry for being cautious!
EDIT: I'm only comparing LPG to WI in regards to the ability of the engine to operate in the absense of the aftermarket system. I am in no way claiming that they do the same thing.
2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
Not including hers...
