DNA Tuning (Australia)
Results 1 to 10 of 10
Thread: VWA Detection of a Tuned Vehicle and the Manufacturer's Warranty?
    I agree, to find out if the ECU or any control unit was reprogrammed is matter of 5 seconds, when the diagnostic unit is connected. So, not much wast of time.
    Sorry Transporter - the good tuners read & re write the flash counter back exactly as it was. It's the cheap tools & handheld units that keep incrementing the number you see in your picture.
    Mar 2008
    Sunshine Coast
    I thought the flash counter wasn't even bothered with by dealer diagnostics any more, they access encrypted logs on the ECU and TCU ?
    Last edited by AdamD; 16-11-2012 at 08:27 AM. Reason: Removed subject from old thread
    Adelaide hills, SA
    I'm not arguing that you can't make the ECU look like it wasn't reprogrammed, but tell me, how is that stalk going to rewrite the flash counter, when switching back to VW stock map? Is it the VW stock map or is it still the APR stock map? In which case it wouldn't be too stealthy, would it?
    Jun 2008
    Ringwood, Victoria
    VAS no longer looks at the flash counter as its sole guide to tuning, from the info I was given, without giving too much away, it's looking more into the actual software itself, like a license key for high end software. If your key doesn't match the same one on the VAG server, it instantly flags it.
    Jun 2008
    Ringwood, Victoria
    Quote Originally Posted by Candyman View Post
    You are correct, there is no point because they now go to far less effort....
    Last edited by AdamD; 16-11-2012 at 08:28 AM. Reason: Removed subject from old thread
    The way that the APR EMCS system rewrites when you switch with the cruise control switching does not trigger the flash counter. It writes the stock VW map back in (but the APR switching code still sits in the background).
    On hand held "controllers" you need to check what the flash counter looks like before & after using them - we have seen first hand that some (like bluefin units & Alientech Powergate units) increment the flash counter each time they rewrite a partial map.
    On ME9, EDC16 & earlier (Golf R, Scirocco R, Golf V TTS etc etc) the check is to check the flash counter.
    On the MED 17 & EDC 17 & the latest Siemos systems >>>> its an electronic checksumm sniff that detects the modified code (online to Germany) and if an anomaly is recorded and the car is tagged "TD1" in the online database.
    If you restore your ECU to 100% factory binary (your APR dealer can rewrite this back in - no problem) then TD1 does not show - but this must be a full rewrite of the ECU, not a partial binary bit that some tools can only do (ALIENTECH, CMD, EVC etc etc)
    On Golf R's and similar family, they still run the ME9 ECU's which are still tagged by a flash counter. On a MK6 GTI or a Polo GTI 6R its the other method mentioned above .
    Jun 2008
    Ringwood, Victoria
    ^^^ this.
    Problem is though that some people have learned this the hard way.
    Mar 2008
    Sunshine Coast
    Wow, info varies depending which country tuners you "talk" to
    Always has been a case of muddy water and fairy dust and sounds like it still is
    To reference a very wise man ....
    Considering the number of people who have had warranty issues rejected with well known tunes.
    You tune, you risk warranty. Simple as that.
    It doesn't matter whether you purchase from someone who charges a lot or someone who charges a little. It happens.
    8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
    Sep 2009
    seaforth, nsw
    A mate experienced this in his mk6 gti. Was running stg 2, got misfires. Removed his parts and recoded, and dealer fixed under warranty. Replaced coil packs and plugs.
    2011 cw golf gti 3dr man-tint-rear cargo mat-weathershields-bluetooth-mdi-19" oz racing ultra leggera-mcgard lockbolts-boston acoustic pro60se-jl audio xd700/5-jl audio bass tube bb-w060p- titanium exhaust tips-eibach custom pro-kit-OPS-OSIR cf mirror covers and cf front lip-dieselgeek short shifter
