Results 11 to 20 of 30
Thread: vr6 turbo
    Jun 2006
    Orange NSW
    Quote Originally Posted by 16v_rabbit View Post
    hey.
    those anyone have a golf mk3 turbo vr6 because i want to make one and i need people to tell me what i need to do to the internal parts of the engine.\
    cheers bois
    You can run up to 10 psi on standard internals as long as they are in good condition with out to many km's on them, but its having a good safe tune that is the most important thing with any custom setup...
    Going the whole hog i would use Pauter rods, 8.5:1 JE pistons, ARP head/rod/main studs, inconel coated oversize supertech valves, HD valve springs, titaninum retainers, light weight lifters, Custom cam grinds to suit turbo, Alluminium flywheel and pulleys, linished crank or reground if required. Fully dynamically balanced, Custom inlet and exhaust manifolds. Port and polish and port match head and manifolds. Garrett GT35/40r with 45mm tial wastegate and a 3" exhaust. Motec or Autronic ECU. Their is so much more things than this though......
    Apr 2006
    VW Race HQ - Sydney
    Im running the standard flywheel and pulley . Why would you play around with the harmonics and balancing of the engine without really knowing its outcome
    Id get the crank knife edged as well
    Jul 2007
    Rowville Melbourne
    can you imagine the time, effort and pain in the @$$ it would be to engineer a twin charged setup? wow. it makes me wanna go get drunk to not think about it at all.
    Nov 2005
    quote of the week, !!!!!!!!!!!!
    wabit
    Sep 2006
    Parkinson / Brisbane
    turbocharging is so much more efficiant than supercharging and u have almost limitless hp capabilities (for a fwd anyways)!
    I've read that the stock internals can hold up to 11 intercooled pounds which I gues would be like 350hp? way too much but very cool. though 9psi is the safe option . . .
    as was mentioned before, get on vwvortex and search till your heart's content!
    Jun 2006
    Orange NSW
    Quote Originally Posted by Bug_racer View Post
    I have balanced numerous bottom ends as an engine reconditioner and though aftermarket suppliers of alloy pulleys and flywheels say they are balanced when you balance a bottom end you balance the crank first and then add the pulley, flywheel and pressure plate and rebalance them all at once because it will be out of balance! Maybe not by much, but a decent amount will effect the bearings life, put undue stress upon the engine and reduce power and the smoothness of the engine under high revs. Knife edging is a great idea to and will reduce rotational mass as well as reducing parastatic frictional losses.
    Feb 2007
    Perth, WA
    Quote Originally Posted by Shteifen View Post
    Says it all really!
    I'd go a blower myself. Love that whine!
    turbo ftw.....
    VR6 turbo would be a better set up i recon, not a big fan on blowers
    Sep 2006
    Quote Originally Posted by GoLfMan View Post
    turbo ftw.....
    Many people have problems with the superchargers on VR6's with slack in the belt, if it is too tight, it puts too much preasure on Power steering, alternator, water pump etc, and eats them for brekkie.
    If too loose then you dont make the power, most people struggle to make over 270hp with a supercharged setup.
    I have read nearly all of the threads on Vortex on this.
    Easy to make power with a turbo
    Also Turbo FTW
    MODS- TOO MANY
    Jun 2006
    Orange NSW
    turbo ftw.....
    Bah, what would you know...
    Put a puffer on it!
