Originally Posted by
Golf Loon
You are wasting your money with a stock engine. You will get about 5Hp Gain for up to $1000 expense.
You`d get more gain from a podfilter and cutting the suitcase out of your muffler.
who said anything about a stock motor?
& 5hp is 5 hp more than i had and its 5 hp closer to where i want to be
Tim
I have seen different ECUs amongst those model years. Some of the 94 ECUs have a different connector on the wiring loom compared to the 95s. Also 95 models have the immobiliser. So even if you have an ECU with the same part number the car wont start without matching the keys to it if you were to change it
arh yes that makes sence now
i didnt relise some of them didnt have immobilisers, that would be why my 94 will start with a simple metal key and my 95 will only start with the origanal
hmm..... i learnt somthing new
cheers for that info
qsz
ECU is behind firewall in engine bay. Should have a Bosch part number starting with 0261.
$450 not $1000. Brand New clearance stock.
Much better throttle response and better fuel econ. with better ignition curves through mid range
Have some Mk 4 GTI as well.
will pull out the ecu this w/e for the number.
also what brand is the chip?
and does anyone have any pics on what to take off to gain acsess just so i can have a heads up on whats involved
(]/_ O _____ O _\[)
"'(O8o)=\X/=(o8O)
[__|========|__]
