Results 11 to 20 of 30
Thread: Viezu Motorsport Tune Results
    Jan 2008
    Sunshine Coast
    F- me, that's not a healthy car mate......did the dyno guy not say something????
    Aug 2011
    Whoa, that second dyno graph looks nasty! I'd say your extra boost has caused some extra problems being close to 95,000 kms.
    Newcastle, NSW
    Yep.
    Pretty standard story. Tune + car with a few kms causes a few underlying issues to pop up.
    Audi S3. Sold
    Golf R. Sold
    Citroen DS3 Dsport. Sold
    2016 Skoda Octavia RS Wagon.
    Quote Originally Posted by Ideo View Post
    Yep.
    Have they not got a plot of the AFRs to check in conjunction with the power.
    Doesn't need to go on a dyno to check them. You can get a good output from VCDS.
    Aug 2006
    Melbourne VIC
    That second graph would be good to ride my bike on!
    Sep 2006
    Parkinson / Brisbane
    Quote Originally Posted by Water Boy View Post
    hahahaha.........
    to the op, why just about slame the tune when Viezu is so willing to retune and work with you, and any other customer for that matter.... makes no sense..... I'd hate to own a company and have to put up with the internet....
    Newcastle, NSW
    Buggered if I know.
    Happened to a mates GTI when we did it as well. Coilpacks, dv and clutch all needed to be replaced soon after.
    So he sold it because "the tune made it unreliable". Not the no servicing for the last 30,000kms or the cheap oil that didn't meet standards, but the tune.
    Audi S3. Sold
    Golf R. Sold
    I wonder if your stock diverter valve (DV) is leaking and causing the up's and down's on your dyno graph as it leaks boost? This is a very common issue in the Mk5 GTI's and can be replaced with a more durable revised OEM valve for around $90 or so. Have a look at Dubaddiction.com.au as he sells them.
    My mate also has the Viezu motorsport tune on his MK5 GTI and the tune soon made us aware of some factory parts that were no longer up to the task (despite a full service history) after 4 years and 70,000km such as:
    - diverter valve leaking (the internal diaphram had a small rip in it which was leaking boost. Replaced with new one from Dubaddiction)
    - PCV valve died (replaced with Eurojet block off plate)
    - coils failing and causing intermittent mis-fire (new coils fitted)
    The car runs well now. Ive been trying to get him to throw it on a dyno to not only see what power its making, but to check the a/f ratios etc, but no luck so far.
    ^ What Lucas_R said ^
    http://viezu.com.au/ VAR Design. Exclusive Viezu distributors and developers for Oceania.
    Some of the best locally developed VAG tuning options on the market now released for ECU and DSG along with some of the best quality and value exhaust ranges /CAI's in Oceania. Put us to the test - 100% satisfaction money back guarantees.
    Adelaide hills, SA
    Quote Originally Posted by KI11Z View Post
    hahahaha.........
    It's OK guys, the OP just wanted to know the experience of other GTI drivers with their tunes and as he said he is still happy with the tune only expected more at the lower end.
    Looking at that second graph there are some issues and the time was set with DUBGTI to look at his car. After all, not everything has to be as new on the performance car that done close to 100,000km and these things can happen and are perfectly fixable.
    Jun 2012
    Sorry where did I slam the Tune?? I have said nothing but nice things about the people involved who are more than willing to help fix the problem.
    I believe I was asking for people's opinion on my state of tune and if it is producing the same sort of results on the dyno and road etc as other peoples GTI's. I felt mine was a little off and decided to see if anyone here could help me with some info, so I knew where I was at in regards to my tune. Clearly there is a problem with my tune as has been stated by many people here and I thank you all for your input.
    I thought that my second dyno run graph was a tad out with regards to a nice power curve, and am wondering if it would be possible to cause a leak from my DV when I changed it to the upgraded OEM Rev D version? maybe I didn't do all the bolts up enough and the added boost from the tune is causing a leak?
    Any other ideas where to look for faults in my GTI, I tired to prevent weak supporting mod failure by preempting them and swapping out the known culprits before I got the tune done. I might look into the ignition system causing issues with misfires as stated in an earlier post and into the hypothetical boost leak I may have caused but not noticed until I was running more boost... who knows.
