DNA Tuning (Australia)
Results 1 to 10 of 10
Thread: twin carb on heron + automatic box
    Jul 2006
    Hey all, so I will be putting a new engine in my mk1 soon (heron motor) and want to run it on twin carbs.
    Quick question, I am retaining the auto gearbox as it is more of a cruiser than a brawler. I am guessing that I will need a manual choke on something like twin 40 dellorto's or weber's?
    Lastly, what is the most readily available manifold to fit duel carbs onto an 8v?
    I have found these and from what my little knowledge tells me, all I would need would be a manifold and choke? Is this wrong?
    http://cgi.ebay.com.au/Ford-1600-CVH...3A1%7C294%3A50
    Cameron
    you should be ok without running any choke, i never did no mine and even started first time in the welsh winters!!!...just ideling is abit of a pain while cold.
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
    Boronia VIC
    No choke required.
    http://www.manifolds.co.za/
    Bit fiddly setting up the kick down but other wise Shouldn't be a problem.
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Jul 2006
    Thanks for that link Pete, its great.
    How would I go about setting up the kick down?
    Boronia VIC
    Quote Originally Posted by cam0x View Post
    Not sure, I haven't really had much of a look at the auto setup in a MK1.
    I'm guessing it's an electrical kick down switch on the carb?
    I'd just take a look at what's there and try to replicate it.
    Just thinking about things , a vacuum resevoir might be a good idea if the auto needs vacuum for anything.
    Pete
    7? MK1 Caddy
    12 Amarok
    Jun 2006
    Orange NSW
    You just need a choke cable. You can buy one from any auto joint. Very easy to install (VERY easy). If i were you i would fit one. Make it nicer with the auto if you ever need it.
    DCOE's have a "choke" built into them. The 'E' in DCOE stands for "Enrichment", ie, it has an enrichment device.
    The beauty of these is that they don't actually "choke" the engine, they simply enrich the mixture, adding additional emulsified fuel to the charge. The chokes are a bit noisy at idle (sounds like you have a vacuum leak), but they work bloody well.
    If you want i can probably get my old choke cable off the Mk1, get my carbies out and mount them to a manifold and take sound pics showing you how it works....
    Also, www.vwparadise.com I recommend these guys highly. They specialise (and i mean SPECIALISE) in aircooleds but they can supply a DCOE kit for you at a good price and their service is brilliant! (Do a YouTube search for "The Nail" while you're at it..)
    Jul 2006
    Pete
    I like that idea of trying to replicate it, it may be a bit help.
    Mate, that would be bloody amazing if you could please help me out with that. This is a big.. and I mean BIG learning curve for me. I will have a look at that site. Cheers
    Jun 2006
    Orange NSW
    I'll Dummy it up tomorrow arvo if i get time and take some pics. I should be able to show you how it all works..
    Perth. WA
    Auto trans set up has the cable going from the pedal to the transmission, then another cable going from that lever to the carby..It should all be on the trans you have in the car now Cam.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Jul 2006
    I have purchased a 32-36 weber with passat ts manifold off this forum, I am also considering buying some 40 dcoes and a manifold from rowland manifolds in sa (thanks again Pete) to get set up right, then ill have two set ups to choose from. What do you guys think?
    I am guessing the one ill need for duel dcoes is
    Golf 8v Twin S/D for Gti Racing 028129589PBY M026
    http://www.manifolds.co.za/?page_id=41
