Page 16 of 18 FirstFirst ... 61415161718 LastLast
Results 151 to 160 of 177
Thread: TurboXS Dump Pipe and Recode Tuning for Golf R
  1. #151
    Jan 2011
    VIC
    I was under the impression that most "tuned" cars will fail emissions anyway..
    Not all 100 / 200 cell cats are the same. Depends on how much precious metal content is in each. You can have an 800 cell cat fail the test if it is a heap of ****...I wouldn't be surprised if most 200 cell cats fail the emissions tests here anyway.
    Then again, at the end of the day, when have you ever been pulled over to get your emissions tested?
  2. #152
    Aug 2009
    Melbourne - West
    APR S2/Whiteline/H&R/Enkei/Carbonio/13.68@101/Winton-1:44.52
  3. #153
    Nov 2009
    we have seen 206kw on a few cars with our off the shelf combination.
    That'd be the stage 3 cars?
  4. #154
    Aug 2009
    Melbourne - West
  5. #155
    In the next few years 100 cel 200 cel 800 cel cats used on any system in this thread will all fail because they aren't in the stock location, things are going to get nasty for enthusiasts here.This applies to victoria already.
    With the sniffer test I've never seen this applied anywhere might be different up in QLD though what usually happens is the police will be fronted with a Dhead who gives them grief and the police will the send them for a full EPA check at the owners expense in the owners own time and they can do this even if the car is completely stock. Its up to you to proves that your car complies.
    We can do the full test on our dyno with the Coda 5 gas analyser interfaced to it and the program run through the various ranges and loads that their test parameters dictate and yes most cars will fail. You could modify a tune to make it pass though even with 100 cel cats but you still fail because the cat isn't in the stock location !!. Actually everyone will fail because their car hasn't been engineered with the fully hektik intake they've installed !!
    End of the day I only know of one car owner being fined for having no cat at all and after being defected three times previously for it and that was an EVO.
    The other thing about the power everyone is getting with brand X exhaust. To some degree you have to have the tune suited to that style of dump pipe eg the divorced setup needs bigger wastegate values to open to a bigger angle to flow the same amount of gas so you can't just say the TXS dump pipe gave me X kilowatts gain. The reverse applies too.
    The only way would be to use the same tune as a base and then modify that to suit a particular style of dump pipe and do it properly without any bias, it aint gonna happen .
    Anyway please continue.....
  6. #156
    Nov 2010
    Melbourne, VIC
    Just let WhiteJames chime in regarding the Cat. Isn't he a man of the Law?
    | Golf R MY11 | DSG | 3 Doors | RB | Recaro | 19" Talladegas | ACC | Sunroof | BT | APR S1 | APR Carbonio | MillteK Sport CBE |
  7. #157
    This is the test quite a lot of our customers have had to pass in QLD (with a 200 cell cat - as a 100 cell does not pass it) I understand from our transport engineer that there are equivalent tests in each state.
    Free vehicle emissions testing (Department of Transport and Main Roads)
    ADR's are different to "In Service" - VIC seems to have the harshest laws period, followed by Canberra.
  8. #158
    Jan 2011
    VIC
    At the end of the day I think if somebody wanted to pick on a modified Golf R they would find any reason to defect it. Especially in Victoria. So let's take the emissions standards out of 100/200 cell cats.
    Fab if you get a fine for running 100 cell cats or 'cats in the wrong location' send it to me I will take care of it.
    Now that that's out of the way..Can continue with the success stories of the TXS downpipe which is what, less than half the price of the "comparable" competitor?
  9. #159
    Aug 2009
    Melbourne - West
    Nice work clem cheech!
    Fab! Im running out of popcorn...
  10. #160
    Nov 2010
    Melbourne, VIC
    APR's just charging whatever the market is willing to pay. So unless there is a change in this trend, the APR DP will continue to exist in the Aussie market. GO APR!!!!
    Unfortunately I can't afford a $2,500 APR DP and will definitely be buying alternatives. Who cares if the APR makes slightly more kWs? I can buy an APR HPFP with the difference in price and get even more kWss!!!!
    Quote Originally Posted by CSR View Post
