Page 14 of 18 FirstFirst ... 41213141516 ... LastLast
Results 131 to 140 of 177
Thread: TurboXS Dump Pipe and Recode Tuning for Golf R
  1. #131
    Sep 2011
    Blackburn, VIC 3130
    Hi all,
    I'm thinking of going Stage 2 on my Golf R. Very very minimal modification. I'm only thinking of getting the TurboXS dump pipe. Is Cold Air Intake required for Stage 2? Or is it just a recommendation. I'm looking at BSH K04 true seal but the original engine cover will no longer fit after installing it.
    If CAI not required, then I won't bother. I'll install TurboXS DP only. Yes, no? Thanks!
  2. #132
    Oct 2010
    I have a modified BSH True Seal intake on my car and am fitting an Audi TTS Engine cover for the more factory look.
    The Intake is required if you want the top end gains as the stock airbox can't flow enough air up top.
    If you want a cover i have them available at a price that is much cheaper than retail Also have R8 Oil Caps and Coolant Caps.
    Absolutely loving my Golf R and hearing the Miss' scream when it come's on boost!!
  3. #133
    I'm still on the stock airbox but Krazie is right, if you want to chase some decent power you'll need one.
    I've got a BSH true seal going on my car this weekend.
    TXS DP and BSH Intake, RS4 valve and tune from recode and you're good to go.
  4. #134
    I Need to order myself a BSH one just so I've got one spare
  5. #135
    Apr 2010
    VW Matrix
    Where are people buying their BSH intakes from? I'll probably get one myself.
    KRA21E - Please PM me the price of the cover.
    GOLF R Stage 2+
    MK3 OCTAVIA vRS WAGON
  6. #136
    Oct 2010
    Speak to Tim from Dub Addiction...He will sort you out.
    Quote Originally Posted by masev View Post
  7. #137
  8. #138
    Point Cook, Vic
    Quote Originally Posted by parso_rex View Post
    Have these gone up in $ ?
    If you are referring to the price on the Dub Addiction website then yes unfortunately they have gone up a little as we got burnt a bit with the recent currency fluctuation.
    FOLLOW US ON FACEBOOK
  9. #139
    Jul 2011
    Berwick, Vic
    Anyone running a TXS DP with a APR stage 2 tune? Seems most posts are from recode customers.
  10. #140
    I believe Fab_R had that setup for a short while but then changed from APR to GIAC.
    Reason most APR cars wont have the TurboXS dump pipe is because APR want you to use their own dump pipes (which are twice the price!!)
    Quote Originally Posted by Boldy View Post
