DNA Tuning (Australia)
Page 10 of 18 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 177
Thread: TurboXS Dump Pipe and Recode Tuning for Golf R
  1. #91
    Sep 2011
    Gold Coast, Qld
    Quote Originally Posted by KRA21E View Post
    Mark,
    With the increase in boost pressure after the tune, im wondering if the stock DV is remaining closed on full boost and WOT...if not, i wonder if putting a stiffer spring inside the stock unit is possible ie where can i find a spring that will fit?
    Any idea's?
    You're talking blow off valve I gather? What makes you think it's not opening, what are the symptoms?
    Golf R - 77TSI engine transplant, 91ron tune, & a crochet rug on the parcel shelf
  2. #92
    Oct 2010
    Blow off Valve (Vents to atmosphere), Diverter Valve (Vents back to intake) are same thing...What i mean is, is the vlave remaining closed on full boost and full throttle and not allowing boost to leak...Just want to make sure that the boost level is not also forcing open the DV.
    btw, your a spastic re your comment in the other thread! lol
    Absolutely loving my Golf R and hearing the Miss' scream when it come's on boost!!
  3. #93
    you've got the later model one, it will be fine. If your still a bit concerned I will sell you my last Kuhneutson Valve for $300 cash
  4. #94
    Sep 2011
    Gold Coast, Qld
    BOV's can & do return as well.
    You haven't answered why you think this is happening? Have you noticed a sudden change? What's happened to make you question it?
  5. #95
    Oct 2010
    Nothing happened, I was just thinking if w are changing the wastegate to make it more reliable, should we beefing up the dv aswell...it very easy to change the spring in the dv, trust me, once you un bolt it, it all just comes apart.
  6. #96
    Sep 2011
    Gold Coast, Qld
    No worries, Mark has replied anyway but I thought you were only going up in boost by ~ 2psi which is bugger all. Maybe it's more .....................
    I don't even know where it is, very easy on a wrx on the top, but if it's in a more difficult spot then it was a good point to think about while you were doing the actuator - now it makes sense.
  7. #97
    Had the car custom tuned today by Mark at recode.
    198kw atw with TXS downpipe and Autotech pump internals. There was more room for boost but he pulled it back until I get some other bits done.
    It's mental to drive and exceeded expectations. I'm dying to see how much power these cars make with RS4 valve, actuator and FMIC upgrade as I can see huge room for improvement.
    Mark can post up the dyno if he is happy to do so.
  8. #98
    Oh you mean this thing
    As usual 10Kph Ramp 4th gear - not that it makes any difference
    Note the stock power. This has me stuffed. It has in stock form somehow benefited from the TXS Dump pipe much as my previous logging and dyno runs have shown not to be the case in the past. The difference is Glen has driven with the TXS/ insert pipe of your choice.... for over 2000kms and not 2 minutes after a remap, I expected the typical 155~160kW atw but no. I will investigate this in more detail when time permits. I have full logs to show the fueling, ignition timing and boost control with the totally stock arrangement, its fine - Apart from the Cat efficiency CEL that you'll see, that won't be an issue with the current file ...
    We did a heap of runs and in hindsight I could have chosen better runs to show the gains but you get the picture
    Goes hard
    Gorans file for reference with the highest stock run
  9. #99
    Oct 2010
    Quote Originally Posted by Large Fruit View Post
    Hahaha, another happy customer!!! It's ferral ay?? One question for Mark though...why the big difference in torque between the two cars?
    Parts are in transit! We will all be happy chappies soon!!
  10. #100
    Oct 2010
    Mark,
    That is different to the printout that i have...oh well, much of a muchness...We really need to work on rounding out that midrange from 3-5k and fix that dip above 6k!!
