That looks awesome! you have been putting a lot of thought into this... I made a similar manifold setup on a nissan ET pulsar running a CA18DET with a t3/t4 though the exhaust was at the front the 3" down pipe i had going over the gearbox and down.
One thing to consider is manifold length although tuned length is good the longer the runners are the less heat energy and pulse from the exhaust stroke hits the turbine. Shorter runners will have improved low end response but dont flow the top end nearly aswell as longer tuned length manifolds.
