Doesnt have EDL (electronic diff lock?)
ABS is completely seperate, ESP is likely tied into the ECU somewhere, not sure if it will stay, depends how it activates.
Normal traction control just closes the throttle, so that wouldnt work, but if may brake individual wheels which should remain active.
And then have the Vipec run its own independant traction control via fuel/ignition cut.
Current: '04 Astra SRI Turbo - EDS IPF Flash, 3" TBE, Quaife LSD
Previously: Bora 4mo, cams, coilovers, tune, exhaust, brembo's etc
